Saw the Avispa at Blade, should've snagged one. How do you like it? Reminds me of a Rat 1.
Beautiful knife, great fit and finish, very sharp right out of the box, perfectly centered blade.
Love the geometry of the blade better than Rat1, compared to Rat1 the Avispa is thinner and slightly less wider, blade and length of the handle are almost identical. Thicker blade at the secondary grind, very smooth action, very nice lock-up.
It is basically Rat1 size and shape of the handle with clip point blade and frame lock.
My only problem with it is that I don't like tip down carry but when I move the clip to the position for right hand, tip up carry it pushes directly on the spring, not on the frame...
Look at the bottom picture, you'll se a gap between the clip and the frame... It shouldn't be like this, I believe they should fix this, simple repositioning of two of the bottom holes will fix it,
a wider clip will fix the already released knives I guess but I don't know if they registering this problem yet...
Otherwise the knife worth every penny, love it and the small Zancudo too...
Here is a big size picture comparing it with Rat 1, I'm only posting the link, otherwise could be too heavy to load in the thread:
http://imageshack.com/a/img849/2875/81f0.jpg
