Just received $26 Ontario Joe Pardue Utilitac Folding Knife, drop point, round handle
I think it's mostly just style, though the "square" handle looks like may be a bit more aggressive grip wise, with the large grooves in it, but I won't know till I handle them. The serrated one I ordered has the "round" handle, while the PE has the "square." AFAIK, they're both made of Zytel.
What is the reason for the two different handles? I assume they are both made out of the same material. I have considered picking one up, but could not decide which handle to get. Do you have a preference between the two? Is one more rigid or grippy than the other?
I have small hands, for me, the round handle fits my hands better and is more comfortable. I would say the coffin handle has a bit more grip to it, though.
I got my PE/square handle today. I can see why these knives get the praise they do. Outstanding F&F (very similar to the budget Kershaws, as someone else noted), razor sharp, locks up like a vault with ZERO play in any direction, and very, very ergonomic. The blade also deploys almost like an AO with a flick of the thumb stud. I think these are gonna become new favorites of mine. I'll have to wait till the other one comes in to compare handles, and I'll also post up a few pics when it arrives. VERY impressive budget knife! :thumbup::cool:
Hey does Ontario's AUS-8 on the utilitac compare to a carbon steel like 1095? Sorry for going off track, just curious. I do quite like both the pricepoint and design of this knife.
Oh for sure. Utilitacs don't screw around. They're one of the best budget blades out right now.
:cool::thumbup:
Got my serrated/round one today. Comparing handles, I'm gonna call it a draw. I thought the grooved surface of the square handle might have an edge over the smoother surface of the round one, but they seem about equal. They also feel quite different, though both are super comfy. The square feels wider near the blade and narrower near the lanyard end, while the round has a more bulbous end and feels more uniform along its length, as far as width goes. They both work great. I'm gonna say it's definitely more a stylistic choice for me, though others may find one or the other more comfortable. In my pics, the lock on the square handle looks like it goes over farther than it does (just a weird angle and lighting, I guess). Both knives lock up the same. ZERO play in either one. If you're on the fence about one of these guys, jump off and pick one up! :thumbup::D
Thanks for the comparison pictures and impressions! I certainly don't need another knife right now, but the round handled version seems to be calling to me.
"Need" has nothing to do with it! :D I didn't need these two, but I'm sure glad I went ahead and shelled out the bux for them (about $58 total for both shipped!). :thumbup::cool:
Well SOA, I don't want to burst your bubble, but yes you do! I have had the round handle version, tanto style blade with satin finish for some time now. It isn't "a beast", or "a tank", or a "poor man's Zero Tolerance". It is easily pocketable, lightweight, and has proven to be a stout work knife for me on the construction site. It is plenty big and sturdy enough for anything you would expect a knife to do, plus a lot more you might not.
It is a very well made knife, the fit and finish on mine is perfect, and the open and close of the blade is excellent. I have seen a lot of knives in this style that are a three times as much (I actually own a couple...) that don't have this level of f/f. The knife locks up as it should, and you can even put the pocket clip where you want it.
After handling both coffin and rounded handles, I settled on the rounded as it felt less likely to give me a hot spot with extended use. So far, so good! I have pretty big mitts, and it is still a comfy fit in hand. And don't worry about the steel, as it serves well in the role in which it is intended. It takes an excellent edge, holds it pretty well, but is a snap to get back to razor sharp after you get it dull.
My ONLY concern for this knife was that the liner lock bar looked a bit flimsy to me. There was no need for worry as the knife still locks up perfectly after a pretty fair amount of use, and as you can see where a previous testor chewed through a 2X4 with no problems. When used as a knife I have no doubt there is plenty of lock there to make any user happy.
This could be the best $28 bucks (delivered) I have spent on a knife in years.
Robert
For day to day carry, I prefer the round handles, but I played around testing them and found that the squared handle version does keep your hand from slipping forward better.
As a southpaw, I had concerns the squared handle version would not work well for me, but no problems.
My ONLY concern for this knife was that the liner lock bar looked a bit flimsy to me. There was no need for worry as the knife still locks up perfectly after a pretty fair amount of use, and as you can see where a previous testor chewed through a 2X4 with no problems. When used a knife I have no doubt there is plenty of lock there to make any user happy.
Robert
Well, I will disagree on the bold points. I do think it is a little tank of a knife. I certainly wouldn't call it lite weight. Further, the liner lock bar is plenty thick. It is not thicker than a ZT 350 or 200. In the other masive Utilitac thread Quiet posted some pics of the Utilitac 2 sitting next to a 350. The thickness of the liners is close. Of the liner locks I own it has the thickest. Now, if we are talking about the width of the lock bar on the round handle version, that is another discussion. Then again, I think if one can damage the lock bar on the Utilitac II the wrong tool is being used.
While I don't think of it as a "tank of a knife", if you read my post carefully you will see that I stated the lock bar was satisfactory.
Blue from my original post. Sorry if I was unclear. When I said it looked flimsy to me, I didn't say it WAS flimsy. It appeared that way to me. But later in the very next sentence, I said (I thought clearly) that there was no need to worry as after a fair amount of actual use, it still locked up "perfectly" (thought that was clear...) and then made mention of another user that cut through a 2X4 and reported NO problems. To be completely understandable, I don't have a problem with the lock as it works and continues to serve well. Last thing there was my opinion that "when used as a knife" the knife lock would be satisfactory for any user. I meant that when it was used as designed, as a knife, the lock would no doubt work well for the user. I wasn't thinking along your lines of using it incorrectly or not as intended (not as a knife) but I agree with you. It isn't a hammer!
I guess it depends on which knives you look at for reference when deciding what a thick (or relatively thicker) liner is or is not. Without getting out my micrometer from the shop and simply eyeballing it by putting the liners next to each other for immediate, liner to liner touching comparison, the liner on the U2 isn't as thick as the liner lock bar on my Kershaw Tremor, Kershaw Tyrade, Kershaw Junkyard Dog II, about the same but just a bit less than my RAT 1, and isn't even remotely in the same ball park as my Bad Blood Harbinger.
To be fair, none of the other knives are in the league as the BBH, which makes all my other folders look like children's toys. 3/16" blade thickness which is half again as thick as the UII, G10 handles (not Zytel/plastic), sabre ground 4" blade not 3 1/2" (but the BBH is still only 3/8" longer), and weighs in at almost 1/2 pound of metal and G10! Now that my friend is a tank by my definition. Of course, YMMV.
And it is within $9 of the Utilitac II's price.
All that being said, one of the knives on my short list is the Utilitac II with rounded handle and drop point. It's a spiffy EDC. Hard to resist such a nicely designed and well made knife.
Robert
I hadn't seen this one before. At just a glance while rushing around this morning it looks quite nice. I'll have to look into it more!
I'm sure it's a good knife, but I'm sticking to my RAT 1 and 2. Nice, slim little slicing buggers.
You guys are really making me miss my Tac.
You want help getting pushed over the edge? They open smooth, slice great, hold an edge pretty well, get very sharp, are comfortable to hold, and are under $30.
Now go get one, or you'll have to sit in the shame corner. :thumbup:
I just ordered the black blade, round handle, drop point (looks more like a clip point to me) last night off the river. Mine was $24 shipped. This will be the first non-KAI produced knife Im buying for my collection. I don't like the looks of the Rat folders but I'm eyeing a RAT-3 fixed blade for a post-Christmas purchase.
