Jute twine!
Is anyone else as in love with this stuff as I am?
It's pretty accepted that paracord is one of the bread and butter items of any good outdoorsman. Super-strong, durable, and can be split into its individual inner strands for other uses. But in my pack, I'd say there is at least as much jute twine as there is paracord.
Why have it? There's still a lot of things that it works great for, better than paracord.
First off, it makes a great tinder. All you have to do is fray the edges (easily done by dragging your blade across it a few times at 90 degrees) and it'll take a spark very easily, and burn for a good while. An even better part to this is that the stuff won't light well when it's in 'string' form (unfrayed). So it's not lightin' up until you want it to.
When making simple camp structures and shelters, jute gives you a strong and 'easy to work with' option. The largest benefit in my eyes (over paracord) is that if you leave some of this behind on accident (haven't we all done that?), you're not littering! The jute will head on back to nature in time.
To a lesser degree, it works better for paracord when you need a simple, tight knot. It's of course all a matter of using the right knot, but the jute will hold very well with even a basic one whereas the paracord can sometimes slip out (this is a wee bit less objective).
Last? It's dirt cheap! And every Wallyworld look-alike has some on the shelf.
This isn't a suggestion that paracord should be dethroned and everyone should start using jute to hang their hammocks ( :eek: ), but rather a reminder of another great option out there.
I just re-read your post, I had missed the bit about it decomposing, I know what you are talking about now !!!
hmmm, you got me thinking about the tinder part. Some very good points there!
I love Jute and use it all the time when making shelters, I also have a coil of it in my fire kit as one of my tinder sources as it will ignite well off ferro Sparks. I constructed a wikkiup using jute twine about 3 weeks ago was bac up at my sisters this morning and checked on it the frame is still rock solid (the litter that made up the roof an walls needed some maintenance, but the jute did it's job...
If you soak it in wax, it makes for waterproof tinder... Just and fyi;).. Also look into sisal, as well...
Jute, did somebody say jute?
jute pouch for mini PSK
sling
jute snapping turtle trap
jute basket
jute bag
another jute bag
replica West Coast Cod net
I've posted some of these pictures before, but lots of new people..........
Do I like jute?
Absolutely! :D
Doc
Hi DOC! Good to see you around, I haven't seen you on here in a while.
I always liked those pics. Your skills with knots/weaving are really impressive to say the least. That's definitely an area marked with 'needs improvement' for me.
Hey Doc,
You ever test out that turtle trap?
No, I didn't, but a couple of people wanted to. The picture is on the Wildwood Survival site and 2 different people expressed an interest in buying it. I built it just to learn how.
Not really interested in eating turtle, although a lot of people like them.
Doc
I like Jute twine. Always have some in my gear.
One thing to look out for, is that there are two types available. The untreated natural Jute is what you want. The other is treated with some chemical and it won't do well for fire duty. Though I havn't tried it, so I don't know this info first hand.
Hey longbow,
The stuff I get here is treated (real nice smell :rolleyes:) but it works just fine for fire. Lights off a ferro rod, or a converted lantern lighter. Will have to try a fuel depleted Bic.
Doc
I carry a good amount of jute twine in my pack too. It's incredibly cheap but strong, so I can use it for projects where i may not want to use 550 cord. Also it makes a great firestarter, so it is multifunctional!
I carry jute in my kit as well as in my vehicles. It does great for fire duty and shelter building. It is cost effective to practice with to, as one of my pet peeves is having 100
6in sections of paracord hanging around. I hate throwing paracord away, as I think I will reuse the stuff, but when its time to use them, I end up cutting off my hank of it cause I forget the small ones I already have at home or something. Paracord is my #! however, I am a paracord mechanic, my father is a zip tie mechanic, and my grandfather was a duct tape mechanic. My wife always says that I can fix anything w/ enough paracord. Maybe my sons will be jute mechanics!!!!
Hey Doc, welcome back.
Got jute?
This is the basic stuff I've got when I'm hiking. The 'biner clips onto my belt so it can't wander away. The lanyard and hatband together are probably 100 feet or so.
For the beads I used what look to be a nut of some kind - it looks like wood but it's pretty oily. When crushed with a rock, they break into small pieces that burn pretty readily. The fid is made from a cow femur and nests in the band until needed to tease a strand out of the tassel, which is made of 6" pieces specifically for firelighting.
I generally have a little blue tin of Blistex lip balm (pj-based) which makes this stuff light on the first strike. Beating the parted strands with a rock or stick helps to 'fuzz' them a little more as well.
Spooky,
I like jute too. I keep a bunch wrapped around my Sportman's All Weather Blanket in my pack, great stuff!
Hey longbow,
Doc
Howdy Doc, thanks for the correction.:thumbup:
Does it keep your gear smellin purdy?:D
