I just received the knife today. These are my impressions. You'll have to trust that I know what I'm talking about.
You have to hold this knife in your hand. It's magic. I know it's weird looking, like a cartoon, but this is a very good knife. I would call it excellent.
I can't use my right arm well, because I strained my rotator cuff last week (that is total sucko, let me tell you). I had to use my left hand, but all still holds true. I drove the point into a iron-hard dead oak tree and pried it over. No bending and the point didn't break. It pulled out a nice divot. Then I chopped into the tree, giving it all I had. I even focused on a knot. The edge is perfect, no chipping or folding and still sharp. Such is what you expect with 1095 American steel, probably tempered in a computer-controlled kiln.
I bashed with both sides of the blade, the back of it, even the tip. No problem. The powder coat is attractive enough as these things go and pretty durable, though I didn't really put it to the test that much.
This is an unlikely dagger, sure enough, but I drove the point repeatedly into a tree and a sheet of plywood. I even drove it through an old flat screen I was throwing away. It pierces very well. The point is full on-line with the handle, so, if you close your eyes, it still thrusts instinctively. Yes I tested that. It actually thrusts well.
It's a bit blade-heavy, as you would expect for a large bladed knife, but it's responsive. It corrects easily and doesn't pull you too far into the slash. This knife is meant to be blade heavy, but only a bit. The center of balance is just at the choil. A heavier handle would balance it for thrusting, but that would be counter-productive. You can always drape your finger over the guard.
The handle is instincive. You know where the edge is at all times.
I disagree with the people who grind off the top guard. I'm a big thumb planter. The guard is set very far forward. It in no way interferes with the thumb in a saber grip. This is a fighting knife, make no mistake. You have to be able to parry with the back of the blade. Your thumb needs protecting while doing this. I would leave the top guard be. Guards are always a good thing if they don't get in the way of your grip.
I see why it performs so well in cutting tests. For one thing, it's razor sharp, with a full flat grind. For another thing, there are no straight edges. In a natural stroke, it cuts instead of smashes.
If you hold a razor blade between your finger and thumb, you can bend the blade in half. The razor can only cut when it slides across the object (called a draw-cut) not when it presses directly into it. That's why curved swords were so popular against unarmored foe. They didn't stick and they cut at an angle, not smash in a direct line. You tear a phone book in half by edging the pages not smashing it with a hammer.
This knife is magic. It looks like it was designed by accident, but somebody thought outside the box and they really succeeded. Don't listen to people who judge a knife as inferior just because it's different. Obviously they have no imagination, just a rigorous adherence to the mundane. Some things just perform magically well, they just do. You HAVE to feel this thing. It's a dancer.
