Got my GATCO sharpener. The box was actually somewhat damaged so I plan on returning it, but I did not notice before I sharpened a few knives.
Got a kitchen knife ultra sharp with a 22 degree angle. Cut through paper nice and I did not realise that bread knives were only ever needed if you don't keep your normal knives sharp. But I had heard of testing a blade on your arm hair, and producing a hair popping edge, the blade did not seem even close to sharp enough to cut a hair easily.
I sharpened a small hunting knife to a 25 degree. It is a thick blade but does paper fine, but it still tears at times without the right angle of cutting. Sharper than I have ever gotten it before, that is for sure.
I did the USMC blade last, to 30 degrees. And only did it to the medium grit, as it was suggested that some coarseness would be good (and I had just noticed that the kit might need to be returned). It got to be about as sharp as I am used to my hunting knife being. It looks like it should perform great.
Still I am not impressed with the KABAR USMC knife. I am sure they used to produce a quality blade, but I have a few issues with their current efforts.
The new material they use for the top of the handle significantly mars the leather, even just the first time you put it in. Eventually it will wear a hole through it and it will have to be replace (I imagine something like a year or two under heavy use) and in the meantime I have had an ugly sheath since I first unsuspectingly put my blade into the sheath for the first time. (
http://www.bladeforums.com/forums/showthread.php/886178-short-kabar-and-mark-I-handles)
And my sheath came clearly damaged, and is not wearing well as all.
The leather handle got a chip out of it the very first time I strapped it on, for no acceptable reason. I do not think that the edges should be so sharp on the leather handle, it seems like it is very easy to damage.
So it is pretty, at least if you never use it, and the history of the blade is nice. But its prettiness is not as hardy as I would of liked, and I think the sheath will quite quickly start suffering from signification structural damage.
