- Mar 3, 2022
Gotta love cells n auto correct... A mag angle cube should stick to the shiny silver bit that says hapstone? I'm 6 hrs away from my thing but i think thats how it works?
Correct, that part should be steel and your magnetic angle cube should stick on the word HapstoneGotta love cells n auto correct... A mag angle cube should stick to the shiny silver bit that says hapstone? I'm 6 hrs away from my thing but i think thats how it works?
It will set you up well for a good finish if you're after a mirror. The F1200 will leave a near mirror finish. I would recommend not stropping with pasted strops just yet until you completely get the hang of sharpening with these systems. If you really want to strop later on and only want 1 strop, then I'd say use 1 micron gunny juice.I’m not great at sharpening or anything, but I’ve got some old kitchen knives and edc stuff I can practice on. Will the set of centaur stones bring my edge to near mirror polish? Or would you recommend a strop compound? Thanks for the info
Yes, correct it is supposed to be ferromagnetic so your angle cube is meant to stick to it. This, I imagine is part of the latest batch that Hapstone is having made with partners outside of the Ukraine due to the political situation there.Another question as I start playing with the R2.
I thought I had seen comments or videos that showed the top of the rotating clamp in the new version as being magnetic for angle cubes. Mine definitely is not, but easily 'fixed'.
Am I remembering wrong on this 'feature'? If so, you would think this would be an obvious enhancement at that is part of the workflow.
I posted about the new stone clamps vs previous generation here in post #64.After looking at the pic i still think the r1 clamp is better. 777 edge has more experience. Hope he'll chime in?
www.bladeforums.com
Any experience with combined metal & resin bonds? Came across those at AbrasiveTools website, being marketed as the best of both worlds…Yes, I have many different diamond and CBN stones - plated, resin and metallic bonded. As far as metallic bond is concerned, I only have Poltava branded ones.
I like the resin and softer bonded diamond & CBN stones for the fact that they act and feel a lot like traditional whetstones and leave a very good edge. They have good metal removal rate vs edge quality.
When it comes to fast metal removal, diamond / cbn plated stones are almost unbeatable but can cause edge chipping when you fully apex the edge on a coarse grit plated stone. FYI, the Chinese plated diamond stones are mostly excellent but they seem to top out in grit at about 800-1000. They sell "2000","3000" etc grits but in all cases and tests I've done, it's all the same 1000/800 grit stone just branded with different logos. These stones are excellent value for money and work very well for quick sharpening. Lubrication helps a lot to significantly extend the life of these stones but eventually they will lose grit and slowly deteriorate in performance.
As far as metallic bonded copper/tin stones go, I do like them a lot because they will give you the same effect as a resin bonded stone in that they can be refreshed and will last a very, very long time. In my opinion they work best with lubrication (I use soapy water) and they cut nice and fast, but they can load up a bit with steel and glaze a little over time. There has been a lot of discussion and experimentation on how to refresh the surface when needed but I've found a Nagura to clean them up well in most cases after sharpening. When they do need some deeper surface reconditioning, some guys use ferric chloride to etch the metallic bond away a bit but that can be very hard to control and can ruin the stone if you're not careful. Plain old silicon carbide with the traditional method of lapping stones work well on them to remove and refresh the top surface. After refreshing the surface this way, some bits of silicon carbide can temporarily embed into the metallic bond, so it's probably best to try and use a grit just slightly below the stone grit if you're concerned about this.
There has been a lot of rumours about using silicon carbide on Poltava CBN metallic bonded stones to refresh them, but it has been confirmed that this is actually how Poltava does it themselves so no doubt - it is an acceptable method.
I like to use my coarse and cheap diamond plated stones for quick metal removal when I re-profile or remove chips from inexpensive steel knife edges, followed up by Venev resin stones. For more expensive knives I use my CBN Poltava 120 grit, followed up by Venev resin diamond or CBN. Note that this just my current method and current personal preference, many other methods and steps also work well.
Nope, never tried those yet.Any experience with combined metal & resin bonds? Came across those at AbrasiveTools website, being marketed as the best of both worlds…
I wonder if it would be easy to tweak the design of your clamp so a concave adapter was more integrated? Looking for something to hold the adapter inline with the clamp. It'd only work with 6" stones but I'm thinking the clamp body longer with the hinge milled into it. Instead of the guide rod coming out of the clamp and into the concave adapter hinge. To make a straight bevel, you could make it so you straightened the hinge n had a zero stop or pulled half of the hinge off n went right into the clamp with a grub screw to hold the rod. The hinge would be under where the hole for the guide rod is on the clamp. Not sure how much of a demand there'd be for that but if you did good with the design I'd buy one.
Way up there on my wish list is all that with a threaded hole on the guide rod side of the concave hinge that fits the og threaded long dong guide rod. It was easier enough to tear down n put together with the og clamp that I miss that feature. I take the sharpener on the road for work so I've probably tore it down n set it up more times than most people will in a lifetime.
It also sounds like hapstone stepped away from this over people not being able to tighten screws right so you might not want to get into all that.
I know the shape I'm talking about is convex but for some reason I always type concave. Normally I catch myself. My bad
It's really only a thing when setting it up or if it falls hard. I pull the convex adapter off the guide rod and hope nothing gets banged around in the case. Sometimes when I put it together the convex adapter isn't inline on the clamp rod with the clamp so I have to gun sight down the sides of the clamp to line up the adapter with it. I can post a pic showing what I'm talking about if it would help. I'd want to get rid of the guide rod coming out of the clamp to convex adapter and have the first half of the hinge for it on the clamp. I forget what I was gonna do when I was thinking about modding it. I also forget where the guide rod I got with the adapter is. I just spun the threaded og guy around and stuck the adapter and newer clamp on it.
The convex adapter I designed works very differently to the "broken rod" hinge type convex adapters. It replaces the rear stone holder with a slotted holder with different grooves, allowing you to mount the stone end (close to your handle) higher or lower for convex angles.
Is it better to have a specific grit Nagura for each grit of stone, or is there a particular all around grit that works for most stones?I've found a Nagura to clean them up well in most cases after sharpening. When they do need some deeper surface reconditioning, some guys use ferric chloride to etch the metallic bond away a bit but that can be very hard to control and can ruin the stone if you're not careful. Plain old silicon carbide with the traditional method of lapping stones work well on them to remove and refresh the top surface.
Glad you're liking your Hapstone R2 - it is an awesome sharpener, no doubt!I have worked through all of my knives with my R2 and am really happy with the results.
I have picked up a knife with a convex edge, and ordered the Hapstone Convex Adapter.
Does anyone have experience using this adapter to sharpen a convex edge? If so, could you give me an overview of the process?
Thanks
