- Aug 27, 2004
I have seen it once. It was a few years ago and a Wal-Mart purchase from a guy that used to be my next door neighbor. If yours is like the last one I saw it could be a combo of all three of the following things to look for.
1)pivot tension probably way loose, more so than is necessary for easy opening.
2) blade is off center when closed so the lock for the blade tip at the tail of the folder on the Chive and Scallion designed to keep it from opening is ineffective since the blade slides to the far side of it and simply gets around it by being off center.
3) combine both of these with crumpling up of your pocket in either a big step up like getting into a truck (the case last time for one I saw, a Scallion though, not a Chive) as would happen when pulling your jeans on and what happens is the excessively easy open blade due to the pivot side to side play makes the pants just have to bump the flipper, the blade play allows the off centeredness of the blade and the the lock doesn't work, so the blade flicks open exposing the cutting edge or the point to enable it to bite you.
In short the last one was operator error from the end line user not noticing the things he needed to notice to maintain the folder and keep it safe At least that was my opinion then and I still feel that the end line user shares in the responsibility of using a knife safely, just as one shares in the proper use of a firearm.
In this case with my old neighbor it should be noted that he had disassembled the folder several times for cleaning and spring replacement leading to this which in my mind anyway takes the factory out of the equation since any loctite applied to the screws by the factory to keep them set, as well as the factory tension set by Kershaw for the proper function of the pivot action was all lost once he took it apart.
I am not saying you have done this ok? Just saying it was the case in the only other type situation I've seen similar to yours. If your knife has any of the above going for it fix them and see if it doesn't improve your folder. If none of the things associated with the last one apply, I'd send it to Kershaw after calling customer service and let them check it over.
STR
STR
