- Jul 12, 2013
I got a Leek...I like it. I don’t have a preference between the Dividend or the Leek, I just use both whenever I feel like rocking one or the other. Both work well, the Leek has a better tip for exact cuts but the tip on the Divie works well too
I would say that would be most likely its sibling the link. I believe they still have the M390, S35VN, and 20CV version still available. I think it is a great knife for the price.
JonesE
Do some of you also own the leek?
If yes, which one do you prefer?
Can someone post a pick of the lock side please of the d2 one. Need to see something before I consider
@grownstar has like 3 of everything...How many Dividends and Leeks do you own?
I'm waiting for my already ordered GFN version, and thinking about ordering a Grey version, and why not maybe the basic version of the Leek.![]()
I bet your collection is crazy....gotta be crazy huge!What can I say? When I find a platform I like, I tend to pick up a few extras.
I've got another Bareknuckle on the way haha.
Between what? The Leek and the Dividend?Which one do you think is the strongest?
Kershaw said the M390 Used was The M390 sheets they had remaining From ZT knives. ""LIMITED-EDITION SPRING RUN: A few years ago Zero Tolerance produced a few knives with M390 STEEL however stopped the usage of M390 when it changed into hard to get. So Kershaw had a couple of sheets of this M390 steel left-over on the factory, so they are the usage of this steel to make a LIMITED-EDITION SPRINT RUN of both the Kershaw DIVIDEND and the fairly Larger-Version Kershaw LINK."Check the Cedric and Ada channel on YouTube.
Few specific call-outs, though:
- Pete has found that the CPM version of D2 doesn't perform drastically better than regular D2, or PSF27 (the spray-formed version of D2). It sounds like the chemistry of the steel just doesn't get much of an advantage from being formed in a PM process
- The best M390 performs about 50% better than CPM-D2, in terms of cut tests. M390 will of course also be much more stain resistant
- Kershaw is not going to have the best M390 or the best CPM-D2, as far as their heat treat process goes, so the max numbers Pete posted don't apply in this case
For the Dividend, I'd expect M390 to perform better, but not drastically better. As long as you don't let it rust, the D2 version should be fine.
