- Jan 18, 2003
Is it me or does the Scallion have a thicker blade?
Originally posted by TT2Toes
Ironman: my blade started to rub against one frame scale when the pivot pin got a little loose. Think it happens due to side pressure from the torsion spring. Anyway, a little LokTite on the pivot screw threads, and tightening with a torx driver, fixed everything up. You may try this if the situation occurs again.
TT2Toes [/B]
Originally posted by tangstamp
One more thing. I have a friend who works here in Texas as a LEO and he informs we that we have some of the most liberal knife laws in the country. I should be able to have my Leek as my EDC without any problems as long as I declare it, if I should ever be stopped.
Originally posted by UnknownVT
Many thanks for your kind words.
We've been told that knife laws can vary by location/municipality - and often LEOs can have different views depending on the circumstances.
So it's probably worth chcecking up on the knife laws for your town/municipality (or where you intend to travel) to be sure.
Quote from Section III of Bill C68
(a) a knife that has a blade that opens automatically by gravity or centrifugal force or by hand pressure applied to a button, spring or other device in or attached to the handle of the knife
Originally posted by fiver
I don't like using the thumbstud at all.
<snip>
Maybe it needs loosened up or I need more practice, but the thumbstud so far I have not been happy with. I was actually planning to remove them, until I remembered that they also act as a stop. So they are staying. I LOVE the index open -- just bang on it with your finger for a pleasing "snap" and a deployed blade
Originally posted by BladeFreak
how far do you have to move the blade to activate the spring, and does the assist kick in gradualy or all at once?
Originally posted by chrisbrogden
Canada's laws defining prohibited weapons read, in part, "(a) a knife that has a blade that opens automatically by gravity or centrifugal force or by hand pressure applied to a button, spring or other device in or attached to the handle of the knife."
<snip> Even if the knife is not loose enough to open by gravity alone, as long as it can be flipped open while holding the handle and not touching the blade, it's technically an illegal knife by that definition.
Well, I'm not a lawyer,
<snip>If it opens by centrifugal force (ie. you can flick it open by holding the handle and not touching the blade), it's illegal.
