I have to admit that this was a bit disconcerting to watch so I just did a quick impromptu test with a control on several of my knives. First I spine whacked them with the common grip of holding the knife by the end of the handle with my fingers out of harm's way. Second, I gripped the same knives very firmly but with my hand right in the way of the blade but close enough to it so that if it did fail, the ricasso would hit the meat of my hand sparing me severe damage. I found a very significant difference in the rate of failure with zero knives failing with the same amount of force while I was "gorilla gripping" the knife, as I would be in a life or death situation. Of course I didn't hit the knives as hard as I possibly could, but I did whack them with the same amount of force and even a bit more that caused them to fail using the end-of-the handle grip.
First, the knives that did not fail with the end-of-the handle grip:
Spyderco Delica 4
Spyderco Military (liner lock)
Spyderco Military (frame lock)
Spyderco Tenacious
Spyderco Gayle Bradley
Emerson CQC-15
Emerson CQC-8
Emerson CQC-7
Kershaw Speedform II
ZT 0700
ZT 0550
Boker Wharcom
Here's the list of knives that did fail with end-of-handle grip, but again, not one failed with an upside down, "gorilla grip":
ZT 0301 (!!!)
Kershaw Piston
Kershaw Blur, de-assisted (this one failed ridiculously easy too, but would not fail with the upside down gorilla grip - I could feel the liner moving, but it did not fail)
Spyderco PPT (this one just has way too early of a lockup and also failed easily with end-of-handle grip, but again, did not fail with the upside down gorilla grip)
Anyway, I've never held much stock in the spine whack test and usually test lock strength with simple hand pressure. To be honest, I still do not hold much stock in the spine whack test, especially when it's being done the way most people do it. I don't recommend doing it the way I did, but at least it proved to me that if you have a good, solid grip on the knife, even under fairly severe force, most modern liner and frame locks should hold up.
I also learned that my Emersons and Spyderco Militaries (my most carried and used knives) have some of the most solid locks around and I have the utmost faith in those knives. :thumbup:
