The 5000 was not redesigned because of safety, many companies update designs to keep with demand and modernization (why do you thing there is for example a spyderco delica 4 or para3?). The 5000 Presidio was never unsafe. Did you break the handles to? That's the only reason I could see them asking for 75 bucks for new handles.
The ease of a lock is not important, the axis lock however has proven to be an unbelievably strong lock. Unless the omega springs broke there are no other points of failure.
The 928 with lock rock should be no problem if you just grab it real hard I thought you said right? That's why it was the best lock you said.
You got it all twisted.
Your precious axis lock was redesigned, three times that i know of...
Both handles were unbroken.
Both omega springs undamaged.
You obviously truly do not understand how the frame lock works, they had a good idea putting that eccentric fastener in the end of the frame lock but it moved the contact point too close to the pivot causing lock rock, thats a design flaw and trying to do a strider g10 back/side was another mistake.
"The 928 with lock rock should be no problem if you just grab it real hard I thought you said right?"
I do not belive that is what i said and why would i use a flawed knife design?
Thats why they went back to the eccentric blade stop which is a good idea.
Since you have all the answers, maybe you can tell me why i agreed to $80 charge on my card but when i called the card it was $178 and change? Without my authorization! When I called your beloved Benchmade and questioned them about the unauthorised use of my credit card they dropped the entire amount! Thats shady.
Your a fan boy, wasn't sure at first.
We're going to have to agree to disagree with no hard feelings on my end.
