- Apr 18, 2017
I love those knives. I know I have 1 by Purna (or shall I say...1 is none)....hopefully I have 1...( 2 is 1)...!!!DD for:
11 3/4'' 10 ounce Chainpuri by Purna. In case I wasn't clear.
Assuming they are still available, I am interested in either:
19 inch 44 ounce Char Chirra by Ram Kumar. Grain mark on handle and rusty blade. $85 YBB
Or
17.5 inch 30 ounce Ang Khola by Lachhu. Red grain mark and hairline crack on horn handle. Karda, Chakma are missing and sheath if bit loose. $60.
Can anyone tell me what the difference will be between these in terms of what type of use they are designed for, handling, durability, etc? I am still new to the world of Kukri's and couldn't find much info on the Char Chirra.
Thanks in advance for the help!
Right off the bat, I'd say that if the knife is meant to be used, and if you are not brawny and you don't have big hands, then I think the Ang Khola will serve you better for general all-around use. This is based on the photo showing the two specific knives (along with the actual weights and lengths), not a blanket statement about those models.
Or
Thank you for the advise guys! It sounds like the Ang Khola will fit my needs better and Bikerector got the Char Chirra anyway.
EMS sent for 17.5 inch 30 ounce Ang Khola by Lachhu. Red grain mark and hairline crack on horn handle. Karda, Chakma are missing and sheath if bit loose. $60.
Hi, James:
There are various ways to tighten a loose sheath. Since it is only a bit loose, it might work to just put a couple of pocket knives or other small tools in the slots for the missing Karda and Chakma. That will press against the main blade compartment and might be enough to tighten it up. (Conversely, if someone has a too-tight sheath, sometimes it is enough to remove the Karda and Chakma.)
If that doesn't work, search Bladeforums for a posting by ndoghouse that has a little tutorial on how to tighten a loose sheath. You can find it more quickly by adding keywords like "loose sheath". The "Search Forums" link is in the upper left area of this page. You can specify the Bladeforums name of the poster, the forum to search, and keywords to look for.
It looks like James already emailed about and paid for the Ang Khola.I'll take this:
I've been away for a few weeks while life was keeping me busy... and to let the khukri fever die down a little bit (not really). I have to say, these deals are unbelievable. I forgot what insane value these are. I've paid the same price for a 4" knife, let alone a 17" M43 which can cut down a forest. edit: (brb selling all my pocket knives for khuk money)
