Cliff Stamp
BANNED
 - Oct 5, 1998
Cheaper blades are usually around 45 RC and can be chopped in half with a 60 RC blade without major edge damage (the edge will still be there). Here is a shot of such a blade I took a few cuts into :
http://www.physics.mun.ca/~sstamp/images/cheap_blade_notched.jpg
The blade I cut this up with was a Strider WB. ATS-34 at ~ 60RC. Edge was ~22 degrees per side, quite blunt as I had previously chopped up a windshield with the same knife. You can put the two knives in a vice and press one right through the other. Nails can also be cut up with such hardened blades.
I can do all of the above with a Cold Steel Tomahawk which is ~15$, and the edge has been drastically thinned out, under 22 degrees per side. This is the only Cold Steel blade I would call durable though, as a Recon Scout lost huge chunks out of the edge (bevel was gone), when it was whacked into rocks while trimming back some brush around a grave.
Glass cutting is about the worst thing you can do as it is very hard and will mash the edge bevel in significantly. However the blade should not break in half, have the handle fall off, lose a huge chunk out of the primary grind etc. . As Bill noted, you are not looking for the blade to be still shaving sharp. What is important is that it doesn't come apart, and that the damage can be repaired with some sharpening.
Working in urban enviroments, such hard contacts can't readily be avoided unless you want to spend a lot of time inspecting, and cleaning the materials you cut. It is much nicer deep in the woods where the worst that happens is just some grit in the bark which is just dulling.
Of course you have to consider the blade, not all khukuris are the same. Some have quite slim edge profiles and would quite likely ripple during the above, however they would also get damaged on the harder knots. In general, anything that can take really hard wood working isn't going to be significantly damaged by fooling around banging it into nails and such.
-Cliff
-Cliff
