To answer your question Jay, rather than take the belly of the khukri bigger, which would increase the gradual taper of the blade and combined with the extra weight of the knife, it's ability to bite "deep" ... what has happened from the first TTKZ Proto's is that the shop, through feedback, have looked at the shape of the existing belly "convex" grind and fine tuned this to a very effective "appleseed" convex shape to radically improve it's chopping power.
The exercise to my mind is akin to fine tuning a bullet design to maximise it's ballistic co-efficient ... VLD bullets ( very low drag ) are basically a re-finement of the simply FMJ shape ... but their ability to drop less and be deflected by the wind less is considerable. Apply this sort of exercise to the cross section curve of the convex grind and you start to develop a shape which "bites" really deep without gaining the disadvantage of the extra weight.
This for me is one of the great advantages of "Busse" as a company ... the engineering attention to detail in making a knife and the work they will put into this is for me akin to the ancient Japanese swordsmiths who around 700 A.D. were refining metal and making swords whose strength and technical "fit for purpose" advantages were way beyond what could be achieved in the western world up until recently.
It starts with the "steel" ... Infi does'nt need to be differentially hardened ... the chemical make up of the steel and the manner in which the heat treatment is applied makes the strength of the blades eclipse the very best properties that were gained from the most technical of differential hardening processes, which were employed by the Japanese. The Noss tests are a laugh to many ... but if you see what their blades stand up to in terms of abuse which "shows" how effectively the "stress" has been taken out of the blade so it will not break ... and yet how well the edge still takes an "edge" ... then you have an ideal beginning.
Combine that with applications like the "light series" of handles now being done where the benefits of CNC tolerances in removing the steel are done to give a handle which weighs less but is still as strong as you would ever need ... and then the attention to detail in the grind and "ideal balance" of thickness of stock to strength required ... you have a company which is fairly unique in it's attempts to make the best "power to weight" performance blades for hard use that I have come across.
If you do a search on the posts I have done you will see I have done many reviews where I have looked at the performance of their Khukri's and compared them to similar weighted axes and to other blades from some very fine makers.
I compared the TTKZ to the Gransfors Brux Small Forest Axe ...
They are about the same size and the same weight ...
To chop effectively and deep with the axe requires a wide cut and a lot of wood to be removed ...
To chop as deep ( each going half way into the tree to bring it down with a lower and upper cut so I could direct the fall) the TTKZ only needed half the depth of the axe, mainly because it is a slimmer blade compared to an axe head and was able to work as fast as the axe if you put the effort in ...
An example of the cuts and their depth after the same amount of time can be seen here below ... you can also see in the cut below the main group on the right hand side the depth the Zilla can go to ...
Taking a view from above the stump you can see that the Zilla chopped in just as far as the axe in the same amount of time ...
And the tree was a full grown mature tree ...
The Zilla also made short work of sectioning the trunk and limbs ...
I prefer to use the Zilla for the sectioning work as the longer edge and the difficult "lay" of the logs makes it a safer and more effective tool as there is greater liklihood of the edge being able to "contact" ... the slimmer profile makes it more likely to "bite" ... an axe is much more prone to "glancing" on a difficult "stroke" where you are working around a myriad of "branches" ... and the warranty on the knife is "lifetime replacement" no quibbles or hassle ... which I won't get if I dink my axe haft by a miss judged stroke where it has caught on a branch ... and soaking and lifting the dent out of the axe haft using a towel and a hot iron is very time consuming compared to the agility I have with the Khukri and if it hits a branch mid swing it usually just cuts through it or sticks in it ... no damage ... no hassle ...
I did alter the grind on my Zilla though ... I took off metal using marker lines to show where on the blade the steel was being removed and "how much" by replacing the lines once they were worn off and using a belt sander and varying grit belts I kept the knife "cool" by taking my time ... but given that these blades are fully convex though you could just say I sharpened and re-profiled the blade ... which gave it a more "appleseed shape" and a sharper edge akin to what the current models now have from the factory ...
I also smoothed off the grips so I could use them without developing hot spots ...
But aside from a basic sharpening and smoothing of the grips to the knife it has had nothing done to it except have the edge stropped back after use and it must have chopped down four or five full grown trees and countless limbing and sectioning as I heat my house with wood burning stoves ...
So the Zilla really is pretty good on the performance aspect as it is ... the only thing I would personally like to try is a "lighter" model which could be worn on the belt for long treks ... my TT Zilla weighs in at 32 oz's ...so does my modified KZII and my Nuclear Zilla at 30 oz's ... so they are all in the fairly heavy bracket ... a lighter Khukri would be a nice alternative and if the balance aspect is kept to the same forward point I think it would chop just as well :thumbup:
