Stacy E. Apelt - Bladesmith
ilmarinen - MODERATOR
Moderator
- Aug 20, 2004
Kanthal?
https://www.kanthal.com/en/products...heating-wire-and-resistance-wire/kanthal-a-1/BTW what options are for the spirals ? What I have is 2mm thick soviet spirals that are just top notch but the guy also told me a Swedish brand that starts on K but cant remember it....
Good thermocouple wire (more expensive) will have 5C of *initial* accuracy. A good controller will add 2C of error on linearity, plus 1C in the cold junction compensation.Hello everyone , I’ve been forging and heat treating in coals since day one and I want to up my game and get a kiln , I am buying it from a local but he said that the chinease pid that it has can have 20-30degree C off from what it shows (...)
YesKanthal?
I used Kanthal A1 to wind my coils and they have been working great. It cost around $50/lb when I bought it, if I remember right.Yes
Is that good and worth it ?
I think I’ll go with the old Soviet spiral , as for cover for thermocouple do I need it ?
so do I need the sheath?
Sorry for the delay, didn't see the question earlier.as for cover for thermocouple do I need it ?
Yes, especially if your system will be continuously or regularly running near 80% amperage capacity of the SSR (IIRC). But this can be accomplished a number of ways. One way (which is what I did on my system), is to use a metal box to house everything and have the box act as a heat sink by attaching the SSR directly to the metal wall of the enclosure. If this isn't an option, due to space or if you are using wood or plastic for your case, then a dedicated heat sink will be needed.the ssr needs cooling
IIRC Auberins has a silicone pad that goes with their SSRs you can add for $1 that's supposed to do the same thingIt is best to use some Heat Sink Compound (white greasy stuff) when mounting the SSR to the heat sink.
Yes I got that as well , Received everything , looks good.IIRC Auberins has a silicone pad that goes with their SSRs you can add for $1 that's supposed to do the same thing
Thanks !
