- Apr 8, 2016
How did you guys do lower angles?
I am just wondering if the same tricks can be used for my DMT Aligner.
Don't think you can do the same with the dmt aligner. But maybe the concept will be helpful?
I’ve owned an edge pro ,wicked edge,lansky and Dmt aligner .Now using a kme and very pleased with the results.
Edge pro,messy having to use water on the stones,holding the stone in my off hand was a pita.I am curious to hear your opinion regarding pros and cons of each system.
The SiC stones for the edge pro work well and are affordable. Not idea for high polish on high Vanadium but will work very well for working edges on most steel.I own both and have numerous accessory stones for each. In their stock configuration, I believe the KME is superior because it offers the diamond abrasives as a standard which is good if you have any of the newer super steels (high vanadium carbide content), as it is better equipped to abrade those steels effectively. For versatility, I'd give the nod to the Edge Pro, particularly if most of your knives are full flat ground or have very long (8" +) blades. However, to get the same performance in terms of being able to abrade carbide-rich steels you would have to spend significantly more money to obtain the diamond accessory stones for the Edge Pro in addition to the standard AlOx stones that come with the system.
I am happy with my Edge Pro Apex for its versatility and many stone options.
Clamping systems seem nice, too.
But KME web page says it has positions only for 17 to 30 degrees, which seems too few options to me.
Stang Bladeworks is right on point. Get the Edge Pro from Chef Knives To Go. Great people and a pleasure to work with.
This might have sold me. Thanks. I'm gonna look online and get it from someone reputable. I'll start with the diamond stone set and go from there. I appreciate the input. Very helpful.It didn't take me long to dismiss the Edge Pro from my consideration waaaay back when I was researching systems. The unit jumping around, having to hold the knife in place, etc. were enough of a turn off for me to pass on it. I was looking for a steady, very repeatable, system. I basically already knew how to freehand so I wanted something that was repeatable.
When I bought my KME it came with ceramics and natural stones. Ron's diamonds were still pretty new and I had to save up for them. I've had my KME for years and have upgraded the knobs/handles, bought the full diamond kit, the pen knife jaws and some strops and compounds.
I have NOT REGRETTED this purchase for one second in all my years of owning it.
Let's address a couple things:
1. Full flat grind: Almost every single knife I sharpen on the KME is FFG and distal taper. It is absolutely doable and not big deal. Pinch hard on the tip-end corner of the clamp and then tighten. That will secure probably 90% of blades. If you have a stubborn knife that just won't hold, a little piece of hockey (fabric type) tape will do the trick real quick. Before I bought a roll of hockey tape I just used painter's tape. Not as good for sure but worked. But again, it isn't necessary on most blades if you clamp them properly. I can sharpen a Spyderco Chaparral, SAK Classic, a Wusthoff 8" Chef's Knife and all manner in between with zero movement issues and no tape.
2. Angles: First, although the slider on the KME says 17 degrees, at the edge bevel it will be lower and is usually around 14-15 degrees. I have a mess of knives with 15 degree factory grinds and have never ran into one that I couldn't match the bevel. And, then as said, you can flip it over if you want much lower angles.
3. Repeatability: I've re-sharpened numerous knives on my KME and have no issues with repeating the bevels. They might be off a tiny little bit due to slight clamping variations but that is going to be true of all systems. I have never seen enough variation to matter. Follow the directions, don't bury your knife into the clamps or clamp it at the ricasso or whatever and you should be good.
I have sharpened up to 9" chef's knives and would say that the KME is best for 8" and under.
While I have the base for the system, I don't always use it. In fact, I just sat in my recliner with the KME in my hand and a beer on the side table and sharpened up my Sage 5 while I watched television. I was struggling to sharpen it freehand and wanted to get a good set bevel. 30min's and um, well some amount of beer, later and done. I prefer using the base but sometimes I just want to chill.
Yes you do have to flip the blade over and yes when you get down to single strokes that can get tedious but it is a VERY minor trade off for what the system brings. Heck, you can get all sorts of stuff for it now from convex grinds to stone compensators to axe sharpening.
The KME is a great system made by very nice and very helpful people.
I highly recommend finding Dean O on YouTube. He has some great videos on the system. I'm not disparaging any system at all, including the Edge Pro, I'm just saying that for me, the KME is an awesome system.
So I went with KME I looked around and the prices are all about the same so I ordered it directly from them. I got the system which cane with diamond stones and added the base. My next decision was lapping film or strop with compound. I read some post and it was pretty much split. I am more familiar with strops then the films. I figured I couldn't go wrong. So I got the 8 piece CBN and strop kit.
I am looking forward to getting it. Hopefully by Tuesday.
Update. Did my first knife, a real cheapie slipjoint. Followed the printed instructions and made it shaving sharp. Took about two hours to follow the directions slowly, reprofile, raise a huge newbie burr and then end up with a big smile on my face.
I’ve been spending some time with the worksharp gss and the Sharpmaker. The KME basic kit blows them out of the water. On to the next knife!
