Instructions for making a box for your knife:
Im not going to discuss safety rules for the use of power tools here. Everyone should already be aware of your power tool safety.
If you use a router regularly you could probably figure this out for yourself so I put this together assuming you dont have any idea where to start. For those of you who could do this without my instructions please keep in mind Ive only been using a router for a few of months and figured this out myself. I have no idea if Im doing this the right way or not so please feel free to add comments.
You will need to be able to cut, route and sand wood stock.
Determine the required size of the box for your knife. In this case I am using two pieces of oak 8.5x3.5x.75.
Make sure that your working pieces are the same size and preferably from the same piece of wood. Keep the grain going in the same direction. Sand the ends so that they are flush and smooth when stacked one on top of the other. You are going to remove the material from the top of the bottom piece and the bottom of the top piece. You may wish to mark them as such with a pencil.
You will now build a jig to hold the piece.
I use a table router however, the table is not necessary, but you will still need a jig and be able to clamp the jig and the piece to be routed to a work table.
If you clamp to a table your jig should be able to hold the piece in place and have a fence as a guide for the router. Since I use a table with my router these instructions will be for that method.
I made a jig that I can place it on the router table and remove it when done and be able to use it again at another time to ensure that each box is the same. I use 1x2 wood for my jig. The inside track for the jig measures 15.45x5.45. This leaves .375 for the sides of the box.
You jig should allow you to move your working piece left and right, forward and backward (away from you and toward you) leaving .375 around the inside edges of the working piece.
Be sure that your jig is centered on the router table or you will have inconsistent edge dimensions. Also, the jig should be square. This is critical.
