Hello All.
New to the forum.
I've just built a 2x72 grinder and I am having some issues that I thought your collective expertise could help resolve.
I am using a 170N gas strut, which I think could be too much tension.
When running the belt in normal operation the tracking wheel is canted over at quite an angle to get the belt to run central on the platen.
In reverse it comes straight off, no matter how I adjust the tracking.
I have experimented with moving the tracking wheel position on the shaft (in and out) and it doesn't have any significant effect. What seems to make a bit of difference is the height of the tracking arm, the higher it is the more angle is required on the tracking wheel. That said I only have 40mm of adjustment on the arm, and I imagine the force exerted by the strut changes over that distance too.
I can't work out what element of the geometry is skewing it. Or whether it is the pulleys which are the problem. I bought the pulleys from an ebay seller in poland who manufactures them. They were quite cheap. From eyeballing it it could be that the tracking wheel is not quite evenly crowned.
Thanks in advance for any tips!
New to the forum.
