- Dec 3, 2013
Is the other spring different enough to allow it to close properly? Ide hate to see it lose any of its length, maybe grind the spring itself and a tad of the belly of the blade to clear it? Drill new rear holes and grind the spring the clear entirely? Brass liner turned out great, thats the spirit!!!!
Matt
Both springs are equally bad. I think it's the basic fitment that's off. It seems almost like they put the wrong blade onto the knife. I haven't tried to get a picture of it, but the main blade had worn a deep groove in the backspring where the tang was rubbing it. The corners are very rounded off on the halfstop. Seems like it was opened and closed a lot without lube. If I swap the springs, both blades have acceptable snap... but I'm still going to need to solve the blade rap problem.
Drilling new holes is a good idea... but then I'd have to put new walnut on because the holes would be off. When I saw the mark on the backspring from the blade impacting it, I figured I could just grind a bit off of the spring. I had no idea the fitment would be off so badly though! it's kind of ridiculous. I think I'm going to pursue the stop pin method, it seems like the cleanest solution. I think I can place it so the pin falls right in the sharpening choil. I don't think the kick will hit it on opening. I'm going to have to play around with it a little bit.
Wow, @HeathH you’re making great progress! I’m enjoying seeing the intermediate steps as you complete them. Thanks for taking the time to record, share, and explain the process.![]()
Thanks sir! Once I get the stop pin sorted out, I think I'm ready to pin it together and start selecting a winner. I am going to order up some smaller steel pin stock for the stop pin, however, I was going to just use a nail, but that feels cheap and seems like more of a short term solution. Once I get the pin in, I will post updates of that process.
Thanks to everyone for the patience. Allegedly my jeweler's saw will get in tomorrow... looking forward to playing with that!
