Rlinger,You are doing very awesome work on your knives,I believe you are a knifemaker already.Me I am still learning new things with every knife.I wish I could remeber the site that was posted a few years ago they had all kinds of bones and teeth,Was curious about a saber tooth tiger tooth on a handle.The site was kind of morbid as they sold human bones but I looked past them at the other cool things they had,they may have some of the bear teeth.Guess I will just have to keep searching.
Toolmaker,Damascus is the name that is given to hammer welded steel in our knives.It can be as few as 10 layers and as high as a few thousand layers.The process is basic,you make a stack of alternating steels such as 1095 and 15n20,then heat them and flux them in the forge then heat again till at a welding heat.Then you hammer weld this stack together and after welding stretch the bar out untill you can cut in half and fold it onto itself then weld again,you keep this process going untill you reach the number of layers you are wanting.At this point you can manipulate the bar by cutting or grinding or drilling just to name a few,then finish forging the bar flat and then to the knife shape.Now grind and finish.You etch it to bring out the patterns in the steel but you can just leave the bar shiny and let it age to see the pattern such as you do in a oriental blade.Now days there is Mosaic Damascus and poder Damascus and even stainless Damascus,all beautiful and getting more and more complex everyday.Just keep hanging out here in the forums and learning,before long all your questions will be answered for you.
Bruce
