- Jun 19, 2012
Try the H&K Axis 14715 or Mini Axis 14716. I have one of each and I love them.
Kershaw leek
[/URL]Ok guys seeing as there are endles possibilites here and im picky
Is there any set of manufacturers i should stick to that offer sub $100 knives
Im digging some of the kershaws and crkts
What are good steels in the sub $100 mark Which steels should i stay away from?
I think im digging the tan handles over black which means composite handles only.
This is a lot of good information.:thumbup:Cold Steel makes some great offerings too. The Recon 1 and Code 4 specifically are two of my favorites. They (Cold Steel) have just started making their knives in CTS XHP, which is a higher end stainless steel -- they used to use AUS 8 which is a good or great budget stainless steel, and you can still find these versions just about anywhere. I have the Recon 1 and Code 4 in both steels, and I still love the Recon 1 in AUS 8, one of my favorite knives, even though it's only somewhere around $50 now. The lock is bullet proof, the design is mean, the steel works, it's stainless, and it's easy to sharpen. The G10 handle is plenty strong in the absence of liners.
The Griptilian is kind of everybodies go-to quality EDC. And it's not a bad one, I'm just bored with it. I have the 553S which is the full sized partially serrated tanto and the 551 which is the full sized drop point and I strongly prefer the drop point model when I do choose to carry a Grip. It's definitely not a bad choice and if you like the design, I'd encourage you to check out the Doug Ritter Grip that comes in M390 for $140, I know it's above your budget, but it's a sweet deal for AWESOME steel.
The Axis lock and the Triad lock, from Benchmade and Cold Steel respectively are both near bullet proof, but the axis lock is significantly more "user-friendly".
More choices: Ontario Rat 1 (or 2), Kershaw Cryo 2, Kershaw Knockout.
Gerber made steel, simply because they can't temper it correctly lol. Other then that even 420j2 is a decent steel, it just really depends what you're looking for. Harder more wear resistant steel holds an edge longer an can be reprofiled thinner but is hard to sharpen, middle of the road steels like 8cr13mov, aus 8a, etc are very easy to sharpen but don't hold an edge as long as something like Elmax or s30v.Ok guys seeing as there are endles possibilites here and im picky
