- Nov 20, 2005
I love these old stories about how we used to be and some of the stupid stuff we did. I learned to sharpen a knife from my Dad and then took it from there on my own.
Um, dude, if you needed a sharp knife and instead resorted to saws or "more vigorous cutting" with dull knives, you actually did NEED a sharp knife. For whatever reason, the simple solution of sharpening the knives eluded you.
I can agree to disagree in most cases, but this one is pretty cut and dry.
I don't get that. Different folks have different LOPs and diffferent cheek welds, which affects bullet impact. Having someone else zero YOUR rifle and you not checking and verifying it, is a good recipe for a miss on a buck of a lifetime!
Sounds like you may be starting at too fine a grit.I should have included that I'm still trying to learn. In fact, I just used a 1000grit on my knife and it is sharper, but I need to work hard at it. While I don't consider it a life skill, it is still something that I want to learn to do well.
It's amazing how many knife nuts I see posting on this forum who have no idea how to go about sharpening a knife and the amount of money they will spend on some super duper set up. A decent stone/stones will do the job if you take just a little time to practice. They are plenty of videos to look at. Yes, you can hold a angle with just a little practice. 15 to 20 deg. per side is just a starting point. Depending on the blade you can go lower or higher. Practice and experiment. Nothing is carved in stone. Just my two cents worth.
My stone is 600 grit on one side and 1000 grit on the other. My blade has no damage so I thought the 600 grit was not necessary. I get a working edge with the 1000 grit, but I want to learn to get the sharpest edge possible.Sounds like you may be starting at too fine a grit.
Is knife sharpening a necessary life skill... still?
