Thanks for the offer Will. I think I'm going to send this one back to Andy to be re-edged.
I'm normally a sandpaper and strop guy. I think I'm gonna stick to that method.
Practically speaking, you are absolutely correct. At 57 y.o. and a bunch of knives in all sizes and configurations, I would hope to live long enough for it to become a practical problem on at least one of them. However, I will likely not live that long. I was taught that the blade should be thinned slightly at each sharpening. Of course, this is only applicable to a flat or a hollow ground knife if sharpening with a stone. Having said this, I do thin all of my flat and hollow ground knife blades when I sharpen them in this manner. This ensures a usable edge geometry over the life of the blade.
Your approach will eventually get into thicker portions of the blade such that the cutting edge (19-20 dps) will get significantly wider to the point of effecting performance, albeit it will take quite a long time. I am just curios if anyone has tried thinning a convex ground knife using the sandpaper/mouse pad approach.
Damn duder
Oy vey
This is why I like brkt. They zero grind their convex so when you strop/ sandpaper you are preserving the geometry of the whole blade.
Quick and dirty way to fix a rounded tip with a diamond stone: https://www.youtube.com/watch?v=VGJ5HwLHzfc
My experience with the Worksharp (KO) has been great. I've sharpened about every kind of blade/steel imaginable - no problems. I'm careful (like with anything) and use it according to the directions. I finish up with a strop. It seems to be getting a bad rap here and I wanted to post my positive experience with it. That said, I don't care if you use one or not... it's just a tool.
