This is a question for those in the know, not preaching:
In the search for that balance between toughness and edge holding, knifemakers select steels and temper them to get what they feel is an appropriate hardness for the intended use. If you want a chopper, you might select 5160 and temper it down 5 points Hrc, or you could choose W2 and temper it down 10 points. When you arrive at 57 with both, one will be tougher than the other despite the identical hardness. Aside from the fact that it would obviously be 5160, does this suggest that the optimal range of hardnesses is much narrower for all alloys than they are typically produced?
