- Aug 21, 2007
Your right I'm lazy and stupid. This thread is about finding a knife with a molded clip not to discuss my car entry habits.
That is not a bad idea. I have some shrink wrap I will try. I also have a spray can of Plasti-Dip that may work, just not sure how thick it will coat the clip (never used it yet) and how much it will grip the pocket.Never called you stupid...
There is a reason manufacturers stopped using FRN pocket clips.
You could always do what I've seen other people do, and put shrink wrap around the metal pocket clip.
The problem is that the metal edge of the clip has put three cuts on my leather steering wheel. It's not so much the "give of the clip" but the metal edge puts a slight cut in the leather. I can feel those cuts/gouges when I drive with what was smooth leather. It's not too bad yet. So far I only have three cuts over the last five years but I quit carrying my knifes with metal clips for the last year to stop any more damage. I miss carrying my Spyderco Navajo because of it's metal clip. Fabricating a plastic replacement clip might work for my Kewshaw because it has three screws. But my Navajo has one large screw. I don't think a plastic clip will stay in place. I have had trouble with the metal clip staying in the correct position. The clip has a small detent that fits into a small hole in the handle to keep it in position. Over the years that detent has bent and I occasionally have to re-bend it. I'm going to try covering the metal clips with shrink wrap or Plasti-Dip if that does not work. I will try fabricating a plastic clip.I support bloody sharp's right to be lazy. There's already enough stuff to be responsible for.
The big issue is you want a clip that has more give than metal clips; but if it has that much give, it's more likely to break. I recommend a pocket sheath that you can clip to inside the pocket so the pocket clip is never exposed, yet it's still easy to access.
Either that, or just get some plastic and cut it to shape and screw it down with the screw on a regular folder.
Zero
