I can do a review of the Gurkha House khukuri, not a problem. My perspective is one of heavy utility so that needs to be taken  into consideration. Anyway, Craig, if you want me to have a look at one be specific about how far you want me to go with the testing and what do you want me to look at. Do you want general performance (slicing, chopping, splitting, digging), toughness (edge durability, point stability, gross blade strength), misc. (handle ergonomics, edge holding, ease of sharpening, corrosion resistance), fit and finish (surface polish, grinds, scabbard stitching, blade fit), or all of the above.
Note that the toughness tests are fairly likely to cause gross damage to the khukuri. The most informative test would just be one where I actually broke the blade and then I could comment on exactly what its limits were. I can understand however why you might consider that to be a problem so instead of actually pushing it to its limit I can instead just take it to where it starts to feel like it is going to give. This is not a guarantee that I won't break it but unless the steel has severe flaws I can usually guess this pretty well. I could simply not do any toughness testing as well as a lot of people are not concerned about this aspect as they don't desire prybar strength in a large knife. Nor do they need extreemly durable edges as the knives will be primarly woodworking tools. So if you are marketing your khukuris along these lines I would take that into account.
Anyway, none of the testing would contain any artifical means like putting a bar on the blade it would be just actual field use.
-Cliff
