Cliff Stamp
BANNED
- Oct 5, 1998
The sheath could be brought to lower temperatures simply by placing it above a very cold source like dry ice or liquid nitrogen, and letting the air gradually cool it down. However the only way to test it with the whole sheath at a constant uniform temperature is to be in that enviroment. Otherwise as soon as the sheath is moved to a warmer enviroment you will get temperature gradients as the outside comes into thermal contact with a large heat reservior. So you would want to be in a large freezer, or in a much colder climate. Or do your tests very quickly after the temperature has been reached so the gradients are small. Kydex is a strong insulator, so heat takes awhile to travel through it. You could measure this by putting a thermometer inside and outside the sheath and watching how fast they equalize if you are curious.
-Cliff
-Cliff
