Thanks to everyone! Next one should be available for the passaround I've been threatening to do for quite a while now.
You mean cut the hell out of tatami mats pass around ?
Sam
No firewood or water bottles
Firewood and water bottles are not Katana test mediums
One because it will damage any katana blade and the other because it is silly![]()
Sam
Looks like you just massaged it back in line and touched it up?I chopped my MechaTi into something hard and it took some damage...
...which I fixed
I've used this machete plenty since then, and the repair has held.
Titanium is amazing stuff.
Water bottles are one of the few targets we pessants can afford!! Also empty liter, 2 liter bottles, gallon milk containers and other heavier containers like tops gallon apple juice (much harder to cut).
I find it fun to cut a row of bottles to check angles, speed and ability to cut multiple times without upsetting the base remaining.
I would love to try some of my big cutters on a tatami mat target! Including some of my axes and my one sword (a heavy ungainly thing).
I think water bottles are a bit silly also. Splitting firewood is also silly, but I'm sure the blade would be ok. In truth I like cutting big green bamboo more than anything else, the bigger the better.
...which I fixed
Big green bamboo is a wonderful thing
The noise it makes is wonderful
Dry firewood is asking for the pass around blade to do more than a katana was meant to do
Great job on that
Just curious, what version of heat treat did you use on the Turbine blades?All right, splitting firewood is off the list. Doing the normal cutting job of a katana, and doing it well, will be a fine mission for the blade.
I think Lorien's blade hit a rock in that instance. That particular machete is one that has the "third" type of heat treatment result, and has a sort of strange plastic feel - a phenomenon of the Ti Nb alloy (I know what produces that result now, but wasn't sure at the time that was made). It will bend as in the photo, while a "normal" one would likely disintegrate some of the sharp edge off and would lose some material, but not deeply so. There are only a couple of them out there like the one Lorien has.
