777 Edge
Dealer / Materials Provider
- Sep 16, 2019
Edit - Gritomatic have these available now. Link at the bottom of this post.
I'm in the final stages of my LeadingEdge V-Sharpener. Once finalized, it should be available on www.gritomatic.com if there is enough interest.
The stone holders will come in 6 inch or 4 inch sizes, and will be able to accommodate any of the common 6 or 4 inch sized stones. Including all Edge pro format stones, Venev stones, KME stones, etc.
The angle can be independently set anywhere from 5 to 35 degrees per side (per stone). You can use a digital angle cube or phone with angle finder app to set the perfect angle required. The final version will have a wider base than the one in the photo. The narrow base might be an option if there is demand for a narrow one.
Pic below is one of my test models of the 6 inch sized stone version.
Let me know your thoughts guys & gals.
Now for sale either in a pre-assembled and lubricated kit, or in a DIY assembly kit:
www.gritomatic.com
Leading Edge V-Sharpener
Leading Edge V-Sharpener utilizes two 6" stone holders and fine angle adjusters. The angle range: 5 to 35 degrees. V-sharpener supports Edge Pro form-factor stones as well as flat-end 6" stones.Attention! Sharpening stones are not included. Don't use strops and lapping films.You can buy the...
