...Or is it 20 reps = 1 set = 1 BP?
Something like:
Light sets = 20 reps per block = x points
medium set = 10 reps per block = 2x points
heavy set = 5 reps per block = 3x points
Yep, something along these lines. I was initially thinking we'd have two point systems, one for bodyweight exercises and another for weight lifting - free weights, cables, and machines. The bodyweight system would be based on total numbers per week, while the weights would be based on points for blocks of lifting in different intensity ranges.
For instance, say the goal for the bodyweight exercises is a weekly goal, with totals of:
100 push-ups
40 dips
30 pull-ups
100 squats
50 lunges per leg
300 crunches/leg raises
Some people would blow away the push-ups in a single set, while others would have to grit through each and every rep. The push-ups, squats, and crunches would receive the least points, perhaps 1 point for every 10 or 20 reps. The more difficult exercises would require fewer reps to earn 1 point.
The bodyweight exercise numbers have an absolute standard - 20 push-ups equals one Becker Point - similar to military requirements or police academies. A 250-pound person has to do the same number of push-ups as a 125-pound person. The larger person has to move more mass, but that person's mass entails more muscle, so things more-or-less even out in the wash. People who are less capable with bodyweight exercises have a goal number of points to hit each week and derive motivation to increase performance to get more points, similar to Move Your Butt.
The weight exercises would have proportional point, based on the relative difficulty of an exercise block. The details of how to sort this are still fuzzy to me, but I like the light set/15-20 rep range; medium intensity, 10-15 reps; difficult intensity 5-9 reps; near-max effort 1-4 reps as ranges.
For instance:
Bob can max bench 300 pounds for one rep. He warms up with the bar, doing 20 reps, earning 1 point. He jumps to 135, does 10 reps, and earns ______. I'm stuck. If he wanted to, Bob could pump out 20-plus reps with 135, but that would drain away energy he needs for heavier sets. If Bob only does 10 reps, he shouldn't get two points for lifting in the medium intensity zone, but get one point if he pushes out 15 reps. There's a contradiction in this system, but I don't know how to work it. We could do max reps and calculate intensity ranges for ourselves, but that's getting a little too labor-intensive for this challenge. I think the more intricacy we add, the more folks will be turned off
For the weightlifting points, we could assign a point for X number of pounds or thousands of pounds lifted, say 1 point for every 1,000 pounds lifted.
For instance:
Bob squats 45 pounds 15 times, 115 x 10, 135 x 8, 175 x 8, 205 x 6, and 225 x 6. The total pounds lifted is 675 + 1150 + 1080 + 1400 + 1230 + 1350 = 6885.
Bob would receive 6.885 points for his squats, or he could round to 6.8 for simplicity's sake.
There are a couple problems with this system, as well.
- First, stronger people are greatly advantaged. Not everyone can lift hundreds of pounds at various lifts.
- Second, the compound movement, multi-joint exercises are much more 'valuable' as points-earners than are single-joint exercises, like biceps curls. The upside to this is there are more strength and metabolic benefits to doing multi-joint exercises than with single-joint exercises. However, I remain convinced there's a definite place for single-joint exercises. My elbows hurt if I only do rows and pull-ups and always skip curls. My 'ceps need direct, focused stimulation to stay as strong as needed for pulling heavier weights.
- Third, calculating the points earned from using machines and cables will get dicey. For instance, I did four sets of leg curls tonight at the gym, going up to what the weight stack read as 255 pounds for eight reps. There's no WAY those "255 pounds" of leg curls should get as many points as 255-pound squats!
There are my current thoughts; I'm liking the direction in which bodyweight exercises is going, but I feel we need some brainstorming for the weight lifting part. Finally, I like the idea of giving people a percentage increase, based on their decades of age. I'd not start the increase 'til people are at least 50, but that's my thinking. I'm 35 and don't feel I need an age handicap yet
