- Dec 25, 2023
??? To sharpen a Scandi 2 the factory/maker's edge angle u simply lay the bevel on the stone; same as sharpening a chisle.
Yes, depending n the grit, it can scratch the bevel, and remove any patina from the bevel. So ...??? Knives get scratched in use anyway. "Big Whoops" ... who and/or y care?
Stropping is the same; bevel against the strop.
(A lot of the times it is only necessary to strop to restore the working edge, regardless of grind.)
Unless really dull or the edge is damaged, a few push swipes on each side has it good to go.
How is that more difficult/harder than freehand sharpening when you need to manually hold the blade at "x" angle against the stone?
My Scandi's (or faux Scandi that are hollow ground, like the CS "FINN BEAR") are the easiest knives I have to sharpen freehand, be it in the field or at home.
Easy enough to do if you have some sort of fairly large, fairly flat surface... IE a normal sized sharpening stone, sand paper and a wood block etc. With a pocket stone or small abrasive rod/ whatever, I find them more time consuming and difficult to do properly than a hollow grind. I'm not the only one who's made note of this fact, heard it mentioned by several fairly notably outdoors authoritys, including Townsend Whelen IIRC.
If you think they are easy to do, or you dont mind packing around the equipmment to make the job easy... thats great. Myself and others feel differently.
