bax229
- May 7, 2016
I need to try some magnacut. Maybe when the Spyderco military 2 is released there will be a magnacut version.
I have three customs in it, a folder, and three productions fixed blades. It really lives up to the hype. A Military in it would be incredible!I need to try some magnacut. Maybe when the Spyderco military 2 is released there will be a magnacut version.
I've yet to buy a military because of the tip down only clip.I have three customs in it, a folder, and three productions fixed blades. It really lives up to the hype. A Military in it would be incredible!
The military 2 will fix that.I've yet to buy a military because of the tip down only clip.
Did you match the original edge angle or check to see if you were actually increasing the bevel angle when sharpening? The angle measurements on the sharpener may not be accurate depending on blade width.I purchased a new knife in 20CV earlier this year, and let's just say it was from a very reputable US manufacturer. I immediately chipped the blade in a couple locations. One was my fault hitting a staple behind some tape. With that said both times the pressure was very light and in line with the blade. I stropped it a few times thinking it was a feathered burr but the chips remained. I picked up a Work Sharp precision adjust, and worked out the chips to a 17 degree angle. The original grind was between 16 and 17 so I figured the steeper of the two would be better. The edge came out great and I finished with the strop. Fast forward to today after cutting plastic pallet banding, and this thing looks like an old hockey player. It has multiple chips and rolls after cutting maybe ten bands. Is this the trade off for edge retention? This has been by far the most delicate steel on the verge of egg shells I have ever used. I am going to profile it again to 20 degrees to see if there is a change. What am I missing?
