I posted on the maintenance subforum a question about the entire pivot unit of xm-18 spinning with the blade but nobody answered. Any trick to fix it?
I use blue loctite on many of my pivots. I let it dry then tighten till blade centered and smooth opening. Not sure if that will help but ive noticed my pivot spinning. I've also never really paid attention i guess.
Are you talking about applying locktite on the pivot screw or the outside of the female barrel? I was not referring to the pivot screw goes out over time (hence the side-to-side blade play may happen). It is that there is no relative movement between the screw and the barrel but the whole unit moves along with the blade.
To anyone....
Are the gen 6 bearings ceramic or stainless steel?
Stainless
My next question is there are any corrosion issues. I'm thinking of the ones in the ZT knives, wondering if Hinderer bearings corrode over time.
Another detail question for those of you here who sharpen on a Wicked Edge or other guided system. What is the factory edge bevel on the Gen 6 3.5" XM-18 spearpoint? Looks a wider than 20dps to my eye. I plan to thin it out but I'm also not a big fan of really wide-looking edge bevels on really thin angles.
I don't have an angle finder, and sharpen freehand, but I am wondering how calibrated my eye is these days.
Thanks in advance.
Thanks in advance.
