Standard78
- Jun 25, 2015
Yes junkyard I see it now.
Silver, most likely just a fine ceramic and a strop would be plenty to fix a usable edge. But if its damaged it could take more. Depending on how damaged it is would be the sign of what to use to said damage. If that makes sense.
I've been using a DMT set-up like Fancier for most of my sharpening needs.
In fact, if someone is looking for a DMT Aligner Kit with Extra-Fine (green), Fine (red), Coarse (blue) and Extra-Coarse (black) hones, i can make that happen. It comes in a blue DMT zipper-pouch and is not the Diafold set. It's what I've used to maintain my edges up until now, you can see me use the green hone free-hand in a couple of my Chamdar17 videos. I recently purchased the Diafold aligner kit, so this one is fairly redundant.
Like Fancier mentioned, the Extra-Coarse (black) is for bigger tasks, I used mine for knocking down edge-shoulders to thin the grind on knives and to sharpen some friends' knives that were too dull for the higher grits to sharpen in any reasonable amount of time. Common practice is to keep a toothbrush and soapy water around to help clean the hones during sharpening if they stop cutting due to build-up.
I know DMT is king, but any thoughts on this Lansky diamond plate?
Any pros or cons with a continuous stone rather than the recessed style like the DMT?
http://m.scheels.com/shop/en/scheel...diamond-sharpening-benchstone--80999-ldb6f-y3
I just ordered one of those Work Sharp Guided Field Sharpeners ($27 at Amazon) since it has the diamond, ceramic, and strop all in one compact package. That's exactly what I'm looking for when out on hunting/fishing/camping trips where our knives (hopefully) get used a bunch in a short period of time.
I think I would save $10 and get it via Amazon though:
http://www.amazon.com/Lansky-Diamon...23&sr=8-15&keywords=lansky+diamond+sharpening
This thing is the cats arse for a versatile take-along sharpener. Doesn't fit in a pocket (I mean it will, but not something I would want floating around in my pocket), but will absolutely be in every pack I take with me. It has magnets that hold the diamond plates on either side, and there is a gap between them that houses 2 broadhead wrench cut-outs as well as enough space to stash away some things - I think I'm going to put a "survival" fishing kit in there or perhaps a small oil dabber.
My uncle had one of those. I'm pretty sure it's in a landfill somewhere now. Maybe he got a bad one but the plates wore out in like a month and the leather strip was useless.
Ummm, it's not a sharpener to sharpen every knife you own. It's to take with you in the field to touch up what you have with you.
Ummm? Lol. He wasn't doing reprofiles with it. He used it to touch up his work knife. Obviously it's not a full on sharpening system.
Definitely a travel sized item, but has still worked well for touch ups at home for me. You know I'm looking to upgrade, though!
