- Sep 29, 2014
Hey, does anyone use worksharp field sharpener and/or have any advice as to how effective it is?
I am a reeeeeal sharpening noob and looking for an easy but effective method (for now).
Edit: i skimmed through a few pages and see that you use and find it quite effective Silver.
I might pick one up and give it a go
I have one and it works well on 3v and 20cv. I brought back my 4.1 and NII with it. I actually like the field model better than the bigger guided system from work sharp.
I suggest you get a strop and learn to sharpen with it before you start using a diamond stone. You have a much bigger margin of error with a strop. A few bad passes with a diamond stone and you could ruin and edge that might just need to be touched up and then you'll have to put a new edge on it from scratch. If you miss the bevel you'll scratch up the knife. I've done both.
If you go with a strop remember not to put pressure on the knife just drag it and let the leather and compound do it's work. It's also a great way to finish a blade after you master using a stone. I use a JRE Industries Strop bat. Good luck with it!
