This comment makes no sense whatsoever. I’ll let you figure out why.If you sharpen the knife at 0.005" bte from having no edge, it will be thicker.
(Closer to 0.010" depending on angle)
I measure after I sharpen
Fair enough, guess it makes as much sense as measuring before sharpeningThis comment makes no sense whatsoever. I’ll let you figure out why.
I do be amazed guys still do FFG on chef knivesConvex vs flat? Where's my popcorn?!![]()
That also makes sense to me. Stuart will have to enlighten us on why it doesn’t.I don't mean to butt in, and maybe I'm thinking about it wrong, but I thought Deadboxhero's comment made sense...?
What I'm imagining is, say the bevels are ground down to 5 thousandths and the very bottom of the edge, thus leaving a slight flat area where the apex is supposed to be. After that you then grind in the apex, which will raise the shoulder up the sides of the bevels due to the grinding away of material on each side of the blade, thus making it thicker at the shoulders where the apex bevels begin, since they're no longer at the very bottom of the blade/edge profile.
Not sure if the way I worded that makes sense, but I'm willing to learn if I'm wrong in my thinking!
~Paul
My Youtube Channel
... (Some older vids of some of the older knives I made)[
Absolutely.FFG is the main bevel. The edge is almost always convexed in some way by the folks I know.
able to do what the knife is intended to do ........end of story .IMHO, Knives should be as thin as possible but still able to do what the knife is intended for. Thin spines. Thin grinds (low BTE thickness), and low edge angles. Get the heat treat nailed.
Hmmm. What grit Gator? right now I am going from a 120 ceramic then to a A100 (220 grit) Gator ... but am using the gator more for surface finish refinement, and trying to take the edge for the primary bevel down to 1-2-3 mils using the 120 ceramic (confusion: I am calling the "main" very wide bevel the "primary" per recommendation of Stacy)...slack belt gator...you can mess with tension to get the desired amount of convexing. The edge stays cool for me since there is no platen
thanks. I need to order some steel from Pops, might pick up some 300 and 160 gators to try. I know there is some, ahhh, "discussion" re. flat grind versus convex grind at the tip - I will stay away from that discussion, but will try this.....hen I actually use a A300 gator for the last bit of real material removal
I have not tried this yet. Any hints on how to do this: Do you use a contact wheel instead of a platen?Another important "discovery" for me was learning how to grind in distal taper vertically on the platen
