DesertDweller
- May 5, 2005
I ordered one CS FJ Low order number
I knew that about the amounts may not add up to those higher number or perhaps even beyond because I have a number that I always select as well. I know on the Anniversary Mistress SE there were "300" however there were LE that were also numbered I don't believe they were sequential to the 300? Cobalt was explaining the SHBM's and had some insight into some of the more rare Ladies and the Numbers and I suspect I interpreted the info incorrectly.Further clarification for some LE's. Just because you see a #999 does not necessarily mean there are another 998 out there...there might be, or you just saw Eric Isaacson's LE.He used to collect them like I collect #27.
If you're talking about the ASHBM's, then IIRC the '300' SE were swedged & marked "xxx of 300", the LE's were both choil which were running along one set of serial #'s, and no choil running along another set of serial #'s. Is that what ya mean?I knew that about the amounts may not add up to those higher number or perhaps even beyond because I have a number that I always select as well. I know on the Anniversary Mistress SE there were "300" however there were LE that were also numbered I don't believe they were sequential to the 300? Cobalt was explaining the SHBM's and had some insight into some of the more rare Ladies and the Numbers and I suspect I interpreted the info incorrectly.
It was NOT the ASHBM's... OLDER models.If you're talking about the ASHBM's, then IIRC the '300' SE were swedged & marked "xxx of 300", the LE's were both choil which were running along one set of serial #'s, and no choil running along another set of serial #'s. Is that what ya mean?![]()
"IF" your numbers are somewhat accurate, and we estimate the size of the partial sheets, I could see the total count being somewhere between 300-500."IF" the Yuge sheet was 4' X 8' (48"X96") that would be 4608 sqin "IF" the Handles were 2"X10" would be 20sqin(would have to split in two 2"X5") accounting for cutting kerf and waste probably be over 200 maybe more.
