- Aug 15, 2003
I live in the alps. I'm often getting up around 2500+ meters, and it never affected my Bic. Maybe higher than that it will, I don't know. Never tried.Originally posted by frank k
BICs may be fine for lighting your smokes, but if you ever use them for extended periods in the field where they have to stand up to extremes in temperature and altitude, getting wet, contact with mud, dirt, sand and must work every time without excuses, you will begin to see their limitations.
For mud, dirt and water, it's not really a problem. You can always wash the dirt off, then let the flint dry and it lights back up quite fast.
Cold might be a problem... as already pointed out.
In that situation? I'd rather have your solution, plus a decent shelter and dry clothes...Suppose you fall through the ice out on a lake and you get yourself to shore where you will freeze to death in the sub zero temps and the howling wind if you dont get a fire going fast. Which would you rather have: your BIC in your shirt pocket with your now soggy smokes and no tinder or a match case filled with water proofed SAW matches with some Vaseline soaked cotton balls inside or perhaps a Strike Force fire starter with a couple of packets tinder cubes in the handle?
Seriously, I store my survival stuff (including the Bic) in those cool, tough, and waterproof Otter boxes. It keeps rain, mud, icy lake water and everything else away from my precious gear...
Cheers,
David
