- May 4, 2015
Buck bantam fits most criteria and is like $20. Case sodbuster fits if you dig traditional folders. Very similar to opinel blade shape and is $25ish.
Was hoping you all could generate some possibilities. Seeking modern alternatives to the Opinel 9 or 10.
Weight - under 3 oz
Blade Length - 3" to 3.5" (ish)
Grind - flat (or convex)
Blade Shape - drop point preferred
Steel - Aus8/420HC/12C27 or its equivalent is fine; preferred even
Price - under $100 (under $50 preferred)
Byrd Cara Cara 2 FRN
length overall 8.563 " (217 mm) blade length 3.75 " (95 mm) blade steel 8Cr13MoV
length closed 4.844 " (123 mm) cutting edge 3.188 " (81 mm) weight 3.4 oz. (97 g)
blade thickness .125 " (3 mm) handle material FRN
Boker Urban Trapper. It'll run you $60-$80, depending on your choice of handle (G10 and Cocobolo are cheaper, Ti framelock and Carbon fiber versions are more expensive.) Less than 2 ounces, 3.5" blade (carries like a smaller blade because it's so slim), drop point, VG-10 steel. It is a slight hollow grind, however.
The Benchmade 531 is the consummation of your wishlist, but costs a bit over $100 unless you find a lucky used one.
It's beautiful and ultralight.
The Kershaw Chill is another to consider, but it's a hollow ground and a flipper. I'm not a flipper (or flicker for that matter) guy.
How about a sog oso sweet. Nice little knife, carries well. On the opposite end of the spectrum, look at a Japanese Higonokami. Real slim & pocketable. Available with some real good steel too. Best made has a nice one or check on Japanese knife direct for the above average ones. Cheaper ones can be found at Blade HQ.
Ontario RAT II
Checks off everything in your requirements and is fantastic knife giving the price point. :thumbup:
Flat and thin, with a small swedge.
What is the grind? It's not documented on the Benchmade sight?
