Ankerson
Knife and Computer Geek
- Nov 2, 2002
What is the max blade thickness that the NMFBM "CG" comes with a 11.5 inch blade length ?
Is 0.264 inch automaticly reffer to the "LE" version?
And if not, so what actually is the different between the "LE" & the "CG" in NMFBM ?
If the "CG" & the "LE" are made from the same INFI Steel, and some "CG" comes with Satin Mirror finish, so what is the different?
Is it only the No. that stamped on the blade?
Thanks
The CG vers varied in thickness because those knives where hand ground and are full convex, it was also a very short run compared to others due to all the extra work involved.
Also those found at the shows will vary from the orginal run as they don't have the shaped scales (Smooth).
If the knife isn't numbered it's not an LE.
My orginal thread on mine pictured.
http://www.bladeforums.com/forums/showthread.php/730888-My-Grail-NMFBM-LE-888-Score?highlight=NMFBM
