The creator of the modern liner-lock himself never felt that his own liner-locks needed an additional safety.![]()
Exactly.Right, his own - meaning the ones he turned out with his own hands.
I don't know about anyone else here, but I have used over my many years knives with linerlocks, lockbacks and framelocks and have yet to have any of them fail on me. I am as confident with a linerlock as with a framelock or lockback, in any order. Unless the knife in question was poorly made, I personally don't worry that much about whether one type of lock is more likely to fail than another. I don't think I abuse the knives I use so again I don't think much about it. Maybe if one does fail on me then I may have different thoughts about it but until then, I'll buy whatever knife that I like regardless of the lock type. I will say that I think the framelock appears to be the stronger of the different types but that's just my own observation.
This maybe the most absurd thing I have yet to read on BF, and that's saying something. :jerkit:
could have been sucky luck, like I said my griptilian and ritter grip pass it fine. Thogh if possible I do ask you to try the test and report your findings. you will notice I hit the knife not to hard but not close to the handle, I hit the knife about 3/4 the way from the pivot.
I don't think that a custom hand-made liner-lock would fail, but otherwise there seems to be no difference between high end and low end liner-lock failures...
True.any lock given the right circumstances will fail.
This is a hornets nest that has been kicked. A well made frame lock, lock back, liner lock or Axis lock should have an extremely low faillure rate. You will probably get hit by lightning before a lock failure occurs.
Troll on.
I have a friend who said the same thing...I for one am not a fan of the axis lock, hav ei owned one? yes.
Did it fail? No.
Some people just dont trust springs.![]()
It depends upon which folders and which fixed-blades you're talking about...but i think its rediculous that people keep expecting some lock to be as strong as a fixed blade.
