- Aug 27, 2004
Pressure testing from putting physical force on the spine of the blade and the point tip third in particular is a good test. I'll tap lightly on my boot toe if it defeats from either of these well, 'hard use' it ain't! Send it in with a note detailing that it defeats from simple spine pressure on the blade. Simple spine pressure is real world. It happens in something as simple as cutting down a cardboard box or field dressing game or other such real world uses. Not that an Emerson is the best for hunting purposes, particularly tanto models but some of the V grind models can do it and I know some that use one for that on occasion. Now of course Emerson has one for hunters although I forget the model.
Spine whacking the thinner titanium and stainless liners and even the thicker ones can indent the lock contact and increase the wear prematurely. Just like anything new you should give it time to break in but even new it should not be sliding off the contact to secure the blade from simple spine pressure. If one of mine did I'd want to know about that to correct it ASAP.
I think it could be argued that strikes to the spine could indeed happen in a close quarters combat knife. I also believe that if the lock defeats from simple spine pressure tests or light taps to the toe of your boot that it will certainly defeat readily in a hard stab defensive strike. In short it cannot be trusted if it defeats that easily. Personally a folding knife for self defense is a last resort and if needed a liner lock would certainly be my second to last choice for anything that would involve straight stabs or thrusts with slip joints being the last choice in a folder I'd even try to use for defense but what do I know.
STR
STR
