5022 said:I have noticed that all the Knife brands that claim to be tactical, use a Liner lock. Companies such as Emerson and Strider and even Spyderco and Benchmade in some cases. I wanted to know why this lock is chosen for tactical tasks. It doesn't seem to be the best placed or the strongest. Why do all of these companies still use it?
It requires side torques, the blade needs to bind in something and then attempt to free by twisting. Since the Strider has a 3/16" blade it is obviously designed to enable heavy side loads, far more than what is required to disengage the lock. Jam the blade in a piece of wood and try to split it by twisting the handle.cdf said:In both cases the blade rounded out the hole , no hint of lockbar travel .
Depends on the knife and what it is intended to do.Lil Timmy said:Here's the question, what is Cliff's favorite type of lock?
When they first came out they were promoted as being able to stand "200 lbs of reverse pressure", this was nonsense for several reasons and I was never able to get clarification on the testing method thus I obviously wasn't running out to order one.I find it very odd that he hasn't tested an Axis lock yet.
I would have to see it to believe it. I don't claim to be the most prolific cutter of carboard on the planet but I have been through a pretty fair amount of the stuff, including the use of an assortement of cutters and knives of both frame and liner lock varieties. I've used knives at each end of the scale, Kershaw Chive to Strider SnG, and, to my knowledge, never come close to disengaging the lock.Cliff Stamp said:It doesn't take a vice, it has happened in weeds and cardboard.
-Cliff
Strider folders are very well engineered. Following are some quotes from the Strider Unofficial FAQ addressing failures caused by twisting and dirt buildup.5022 said:... I wanted to know why this lock is chosen for tactical tasks. It doesn't seem to be the best placed or the strongest. Why do all of these companies still use it?
Yes it is well made for a integral, so are lots of other knives, however the lock type itself has an inherent instability which Mick himself admitted for the production version and would not comment when I asked him directly if the custom behaved any different. By the way low partial engagements such as described in the above induce a huge shear weakness.dino said:Strider folders are very well engineered.
Torque failures are well known for liners and integrals. It seems more likely to me even if I had not seen it that this would be true rather that there is a vast conspiracy of individuals out to purposely discredit the lock, especially when some of the people involved like Joe have extremely sound reputations for solid user feedback and makers have taken steps to address it (LAWKS).gajinoz said:I would have to see it to believe it.
I have done it they will. The lock is much stronger actually. I jammed a Chinook II into wood to the point where I wasn't stong enough to rotate it and it held up fine under rotating torques. If you won't twist or pry with folders as heavy and thick as the Striders then all their mass is a waste.cdf said:I honestly dont think any folder regardless of lock type , including the Spyderco Chinook and or Manix will bear up well under those circumstances .
I have not handled anything I would classify as being suitable for "hard-use". The Manix comes close in many respects, solid grip and lock, but to really fill that label the point would want to be heavier to allow deeper prying in woods and use a tool steel instead of S30V as it is not very flexible. I would also extend the slabs up further on the blade to support the piviot in prying. The 710 M2 is probably one of the better choices as well.Lil Timmy said:...hard-use
Cliff,Cliff Stamp said:Yes it is well made for a integral, so are lots of other knives, however the lock type itself has an inherent instability which Mick himself admitted for the production version and would not comment when I asked him directly if the custom behaved any different.
I would have to disagree based on the fact that friction is independent of the surface area in contact. It's just as hard to push a desk upsidedown as it is to push it on it's feet.Cliff Stamp said:By the way low partial engagements such as described in the above induce a huge shear weakness.
Yes. I specifically asked Mick, among other things are the customs problematic under the same conditions which broke the lock on the Buck/Strider. I also asked him, when users were claiming extreme toughness would he warrenty his folders under the kind of heavy use I did with the Chinook. He would not address either issue.By "production version" are you refering to the Buck/Striders?
Shear cracks are not friction based. When you load the lock by prying vertically, if there is only light partial engagement you can shear crack the lock as part of the face is loaded and compressed and part is not. The less then engagement the easier the lock will be to crack.I would have to disagree based on the fact that friction is independent of the surface area in contact.
Thank you for clearing that up. If I understand correctly you are refering to a piece of Titanium cracking off the lock bar. I thought by "shear weakness" you were refering to the lock bar slipping.Cliff Stamp said:.... Shear cracks are not friction based. When you load the lock by prying vertically, if there is only light partial engagement you can shear crack the lock as part of the face is loaded and compressed and part is not. The less then engagement the easier the lock will be to crack.
-Cliff
Nah, a lot of people make a big deal about lock bar thickness and such to enhance security, but this doesn't do much for that.dino said:...the lock bar slipping.
