- May 23, 2007
DONT have either one. Would if i could afford one. Love the blade shape. Just posted to make sure y'all had enough Mikes on this thread.
Get an aluminum can and cut yourself a strip from it. Hold one end and bend the other end back and forth about a half inch. Enough to flex it but not put a permanent bend in it. Start counting then come back and let us know when it breaks in half. Don't hold your breath. If the metal doesn't take plastic deformation, a permanent bend, it will flex for many tens of thousands of cycles without breaking. Now if you put a permanent bend in it and do that a couple times it will break, but so will steel and titanium. In this manner aluminum will break faster than other materials but they will all break in fairly short order. Non permanent flexing is why leaf springs last for many hundreds of thousands of miles and still work long after a car wears out and no longer runs. Aluminum is not a very glamorous knife handle material, but it should hold up fine. There have also been prototypes around for over a year and I'm sure Lionsteel would not make a knife that would end in problems, even though they would stand behind every one.
And my name isn't Mike. Hope I'm still allowed to post.
We have tested daily for more than one year samples made with alluminum frame... no one problem.
hmm now as to whether i should get one?!!11
My concern isn't with strength exactly, it's with the repeated flexing of the lock bar. Aluminum isn't exactly known for being a metal that likes to be repeatedly bent. I worry that the lock bar cutout would eventually develop a stress fracture at the point of maximum flex.
Of course, aircraft wings are made of aluminum and they seem awfully bendy when I'm looking out the window at them, so what do I know?
Yeh, so the question begs, will they replace one if the lockbar breaks at the cutout from metal fatigue?
OF COURSE... LionSteel knives are under guarantee for all structural problems
The amount of bending taking place vs. the thickness of the lock-arm results in such a small ratio... regardless, I'm sure they have a Ti with your name on itI'm sticking with the no aluminum frame-lock stance...
