- May 7, 2005
No, they are not.Isn't liner lock and frame lock the same??? In doubt I'm asking???
Stud lock
Hawk lock
Frame lock
Stud lock, really? Doesn't the entire thing depend on a tiny little coil spring and a small little indent onto the blade?
I've never owned one, so I'll have to take your word for it, but my impression was that the stud locks don't have a whole lot of 'meat' to them.
if you had to list down the most sturdy and trustworthy type of locking mechanism for a folding knife, 1 being the one you would have more trust on not failing and 5 being on the low end of the list, how would you list them?
I'm just talking about the theoretical strength of the lock design, not considering any brand preference or the steel used in the lock.
Here we go, with my reasoning:
1. Compression lock--the stop pin or lock bar must break for it to fail.
2. Frame lock-- the harder you squeeze the knife the more force that keeps the locking bar in place. Minimal parts to fail.
3. Axis/ball lock--like a compression lock except there is a spring (coil or omega) that must hold the locking piece in place.
4. Lock back-- depends on the fitting of the lock bar and the strength of the spring.
5. Liner lock-- quality of fitting is everything. A poorly fitted liner lock can be made to fail very easily.
The stud lock rests on a shelf made into the knife frame or liners, and is the only lock in production that is forward of the pivot. From a leverage standpoint, this is the strongest place to put a lock. The spring is there to act as a release for the stud.
Here's a discussion on the lock, and a little insight on the designer's thoughts.
http://www.bladeforums.com/forums/showthread.php?p=5517660#post5517660
I would rate the Ultra Lock as beng stronger than the Axis cause when the Axis is used more the bar wears towards the pivot (hence reducing lever arm distance) and the Ultra's move away from the pivot after use.
Folder locks:
Best: Any locks on quality knives
worst: any locks on POS junk.
Folder locks:
thanks for all the replies guys
My main concern is if a folding knife made by any of the well regarded manufacturers (Kershaw, Spyderco, Benchmade...Cold Steel?) will close when the blade is driven straight into a target with about 200 pounds behind it. I'm considering this from a SD point of view. I know this may seem a little extreme to consider, but the last thing I want to happen is for a folding knife to close on my fingers in a SD situation, and I know of someone who's had that happen to him.
