- Jun 16, 2003
Good point.
Good point.
xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
Ok, some of you are missing the point completely, when a knife is called " paramilitary" is not intended for cutting oranges, so don't come here to discuss "EDCability" and cutting ergonomics. The knifes compared are not Swiss knives, they are intended for use and abuse. Shame on Cold steel if they were bragging over tri ad lock exploits against buck or Boker classical slip joints , which are not intended to de used as tactical folders. But if you pic a knife that is called "Military" or " Para -military" then customers are being misguided on purpose toward their intended use. My five cents ..
The Para-military was designed for use by military personnel, for tasks like opening MREs, etc. Utility tasks. If you are using a 3 inch folding knife for combat, you won't last too long.
Cutting is basically down to edge geometry, and how long it holds the edge is down to metal composition and heat treatment.
I have an Eland that is 5¼" of razor sharp cutty goodness. Sure the 4116 doesn't hold the edge for a long time, but it resharpens easily too. Heck, I have a couple of Spanish navaja that take a sharp edge easily on 420 steel. I've never used them for more than cutting paper so I don't know how long they'd hold that edge of course.
Put the old AUS8 4" clip point Voyager up against much more expensive knives with their chunky sharpened pry bar blades and it'd cut rings around them, at least until the edge faded. On the other hand an Opinel #8 would outcut the Voyager and even when the edge faded the sheer thinness of the knife would keep it cutting quite well.
Cold Steel make good cutting knives, just like Spyderco do. They do these lock test videos because, from the start, their shtick has been making strong knives. Do they need to be that strong? The ring lock on my Eland is more than strong enough for my usage, and if we want to talk about using a knife as a weapon, it's likely that more people have been injured or killed with cheap Okapi ring lock knives than with Espada XLs. They don't need to be that strong, but Cold Steel put their money where their mouth is and make them that strong, so they're going to advertise that fact.
To be fair, their slogan is "world's strongest, sharpest knives". Yet they never do any head to head testing to show that theirs are the sharpest. If other companies made those claims I'd expect them to do something to back them up. Like I mentioned earlier, if CS really does use thin grinds and makes their knives sharp I cannot understand why they don't test their knives head to head and show that they outperform competitors' knives. That would give them some really huge bragging rights. But I guess CS wants to focus on locks all day long. Cool I guess. I don't really pay much attention to that when purchasing knives. My slipjoints would probably fail at 10 lbs and get rejected.
And the testing isn't nearly as dramatic. "As you can see, our knife cut through this sheet of cardboard using only 2.2lbs of force while the competition took 2.6lbs. A clear victory." More important, but a lot less compelling.
If we're talking about the blade not folding under load, use one that didn't need a "repair" as part of its construction. :thumbup:
No need to wave. Fast to deploy. Easy to clean up. Lighter for the same blade. Probably cheaper for the same blade.
. . . or less. But who cares? If you can't operate a slipjoint without running the risk of injuring yourself, you shouldn't own any slipjoints.My slipjoints would probably fail at 10 lbs . . .
I didn't have any trouble understanding what you were saying, Thomas. And as far as I'm concerned, the only reasons to prefer folders over fixed-blades are convenience, concealment and compliance.No need to wave. Fast to deploy. Easy to clean up. Lighter for the same blade. Probably cheaper for the same blade.
Good thought[/B] bld522, but that's exactly the point, a knife is a poor compromise for everything except for food prep and opening cardboard boxes, even a cutter is superior to it in that sense, but a knife at the shame time is/ should be an universal tool if need be. A knife is what you have when a less than ideal situation arrives
