- Mar 26, 2013
I would do a poll, but I'm not able to post one, so tell us which of these three most common folder locks are the strongest in lock strength?
Strongest in what way? We need a lot more details about this sort of stuff before we can even begin considering any sort of answer.
From what I understand, the order from strongest to weakest (on average) is: lockback, frame lock, liner lock.
It's important to understand that there are exceptions though.
I've never understood this debate. If your worried about a lock failure then get a fixed blade.
That said I'd speculate a liner lock to fail first due to less material.
I have seen different lock stress/ failure videos on the interwebs that may tickle your fancy.
I think they're all good strong locks, it's the one you have the most confidence in that is the strongest. For me, it's the frame lock
That's probably not exactly correct in "scientific" terms.![]()
WE or you...lock strength.
WE. Asking which lock design has the most strength doesn't give all of the relevant information. Exactly what is the knife in question going to be put up against, that you worry might cause the locking mechanism to fail? Batoning? Fighting? Shelter building? Throwing? Cold Steel-style torture test where you hang from your knife for your very life?
There was this video that BladeHQ put together.
[video=youtube;4KmHfbG7z7g]https://www.youtube.com/watch?v=4KmHfbG7z7g[/video]
In their tests, it came out: Lockback > Framelock > Liner lock.
They test one sample of three different knives using each type of lock by hanging weight off of it to try to bend it closed along the pivot. In their tests, the lockbacks they tested were able to withstand more weight than than the frame or liner locks. And based on your personal preferences, there can be other pros and cons to each lock type beyond just how much weight you can hang off
Really, you also need to look at what actually failed during the tests and analyze that (which they do very briefly at the end of the video). For example:
Lockback - The Gerber failed because the weight tore through the handle material itself. So, a conclusion might be that a steel lockbar anchored to FRN might not be as strong as one anchored to brass (eg. on the Buck). Also, the way the Tri-Ad lock is designed on the Voyager is a bit different than a regular lockback (the stop pin absorbs a lot of the force), so it won't respond in quite the same way.
Linerlock - The Tenacious looks to have a thicker liner lock than either the CRKT or 5.11. So, a conclusion might be that a thicker liner lock is stronger than a thinner liner lock. They could also have had different widths on the lockbars themselves, which would have also been a factor.
Framelock - The failures here seemed to be that the lockbar cutouts warped. Similar to the linerlocks, this probably comes down to how much steel is in that cutout section and how much force is being exerted/transferred to that.
He's using subjective data, and that's fine, if it satisfies him. Re-read Post #10.
