bodog
BANNED
- Dec 15, 2013
For now, and just for now mind you, you get the prize for subscribing to the K.I.S.S. principle. Thank you.![]()
You also have to keep in mind that the way they tested those locks was kind of skewed leading to the backlock "winning." When they put the strap directly across the backlock, that means that the more weight that's added then more weight is there holding the lock in place. If they wanted to do it correctly and account for that variable, they would need to create the same corresponding pressure to the liner and frame lock bars to keep them in place. If they'd had 300 pounds compressing a thick frame lock into place while simultaneously seeing if 300 pounds would cause the frame lock to slip out of place, I'm sure the frame lock would fare as well or better than a backlock, especially if you're comparing a titanium or steel liner or frame lock with titanium or steel handles against a backlock with plastic or g10 handles.
