- Mar 1, 2010
I've never had a liner lock fail; nor a lock back (don't like frame locks). That's with just normal use. For heavy work, I use a fixed blade.
Rich
As the OP posted twice, read post #10.
Rich
I first logged on here about 14 months ago, but I'm not terribly active.
I'm trying to understand why there's this tone of contentiousness in threads like this.
The question is a good one. No need for pompous demands or sarcastic answers. But you guys will have to work it out.
I appreciate the info I've found here. . . . . but wading through this cr*p is tedious. I wouldn't think it's good for the forum.
I would do a poll, but I'm not able to post one, so tell us which of these three most common folder locks are the strongest in lock strength?
The problem is that he is asking people to make a factual statement knowing the answers will be based on assumptions and opinions. That never goes well. You can't answer strongest without more specific parameters. If he had asked what is your favorite lock type, or which lock type do you own the most of, this thread would have taken a very different tone.
Can you name the particular knife maker for each lock you are inquiring about? Who makes the knife has a lot to do with the strength of their lock, steel, construction, etc.
Again, and for those who missed it, or choose to ignore it, read Post #10.
I'm not aware of anyone's post here suggesting there's a worry about lock failure...the premise is simple, which lock type, in the objective opinion of the respondent's, is the stronger. You can state so based on stylistic preference, subjective data, opinions of your friends, or base it on scientific testing; make the choice and back it up as best as you can.
I read post #10. You reiterated exactly what I pointed out that was wrong with your initial question.
The fact that you pretend to not see the inherent problem with the question is why some seem to think that you never intended this to be a serious thread.
Will someone please tell me a few lockbacks to look at that are supposed to be the strongest, those stronger than other locks?
And then educate me as to why said lockback IS stronger.....
I personally have no knowledge of which style of lock is stronger, or better, or whatever. What I do know is that I prefer the lockback style for purely aesthetic reasons...it makes for a more appealing folder, with a pair of scales that match, and a lock that is essentially out of the way. While I am fairly certain that each lock style offered will offer benefits unique to their design, I have noticed that I am not a fan of frame locks...again, for purely aesthetic reasons, what with the single scale, a slab of metal on the other side, and a rather quirky lockup that each knife brand displays. Liner locks don't do it for me as well, as I prefer the liners to be a non moving and integral part of the scales. Then there's the compression lock on the Spyderco PM2...I like that lock if for no other reason than it's different.
This debate has always irritated me because people are deliberately ignoring the other option: fixed blade. If you have to ask yourself the question about lock strength, you should be considering a fixed blade.
When I buy a folder, all I want it to do is not close on my under normal use and a little extra thumb pressure. The only ones that have done this for me is the cheap folders like my ESEE Zancudo (frame lock)
Besides, frame lock's inherent problem is that when the lock bar finally wears out, you have to replace a huge portion of the knife. Companies like strider have a cheap fix for it when they could be using a lock bar insert to avoid the unsatisfactory fix)
