Longest battery life - Waterproof LED
Have a Surefire EL2 Outdoorsman - love it, because of the size & clip.
I don't want to go any bigger than that for edc.
But 4-6hr battery life is max for it.
What are some other alternatives - need something rugged / impact resistant - and most importantly looooong battery life.
If you have a suggestion, would you mind to include how long the battery life is?
I've heard Novatec is the way to go???
sp
eternalight.....3xAA liths....floats and is waterproof.
on low low....it will run for 24/7 for 28 straight days. confirmed here at CPF about 2 yrs ago. :eek:
that is NOT a typo!!! ..... guess whats in my BOB? :)
Bill
For several years I've carried two of the white LED version Inova Micro-Light (aka Mini-LED model) on me 24/7 (a user and a back-up spare).
Runtime on a pair of 2016 batteries is rated at 72 hours.
They are listed as "water resistant" not water-proof. However, the first time I saw this model the vendor had several of them burning brightly without problem in a jar of water, as they had been for the last day or so. I've had no problems with any of mine (have them on me and quite a few more stashed in packs/kits) during rainy outings or staying soaked in pockets for hours.
The Inova Micro-Light does not have a tactical light's output. But it provides enough illumination to make your way down the trail to the outhouse and back okay. I've also found them handy for "around the house" navigation while visiting friends or when I don't want to wake/disturb others by turning on room lights.
To me, the strong points of this model are its ease of carry due to small size (about the size of a US quarter-dollar coin), light weight (less than an ounce IIRC), reasonable water-resistance, its price (around $6 cheap ;) :D ), relative ruggedness (no deaths in a few years rattling around on a keychain with a wad of keys), and having both a momentary-on pad switch and a constant-on slide switch.
Downside is that not every gas station or hardware store carries CR2016 batteries, whose price can range from around $0.50 to $2.00+ each depending on where you find them.
I have an HDS U60, which is the precursor to the NovaTec. It's an absolutely great light, you're able to choose the level of light you need for the situation. Low level is all you need for most walking around in the dark, so battery life is loooong.
I also have the new SureFire L1 with the Cree LED. Simple pushbutton for momentary two levels of light or twist for constant on. I really can't tell you how long the battery lasts, I've had it for several months and use it 3 or 4 times a week for 15 to 20 minutes and it's still on the original battery.
Neither light is cheap, but they are both bombproof, and they will absolutely work when you need them.
I have a Gerber Firecracker that lasts a long time. I probably have at least 5 hrs on the same battery.
Pretty much any of the Chinese AA lights with multiple levels will fit the bill for you. The high level will give you a bright light if you need it, and the low low will last for days, or even weeks. Some brands to look at are Jetbeam, Fenix, Lumapower, and Edge-Tac. Most can be had for around $40-50 or lower if you shop around. Head over to candlepowerforums.com for obnoxious amounts of information.
Nothing fancy, but waterproof and impact resistant. Those flashlights that you shake and and they are good to go for a little while. It will last forever at the sacrifice of having a powerful beam. You can find them in boating sections of sporting goods stores for about $10.00, 8-9 at wally world and in different sizes.
Innova x5 is definitley tough and waterproof, and lasts for quite a while, 12-20 hours I believe. You can find them for about $30, and they're made in the USA.
The best approach to lighting is the same as knives - use a combo. In the wilderness I use a Petzl TacTikka headlamp and a Fenix L2D. The Petzl is more than bright enough for regular night time camping/hiking and the baterries (3xAAA) last well over one hundred hours. When I really want to light something up I use the Fenix.
I just picked up a Princeton Tec Attitude from EMS. Its small, runs off of 4 AAAs. It has a huge burntime of 150 hours (3 leds). It is made of polycarbonate so should be fairly strong. Its also waterproof.
Vote number two for Princeton Tec. I have an Attitude and Impact. Waterproof, tough and longlasting. Check it out.
Found them, Faraday shake lights:
Model: SHK-4
Features:
Value Added Club Pack
Bright LED light
Never Needs Replacement Bulbs
Convenient Shake Light- No Batteries Needed
Shock and Water Resistant
Shake 30 sec. get 5 minutes of light
Easy Press On and Off Button
Provides Security
Includes 2 Large and 2 Small Flashlights
One more thing I thought I should share, it's a little bigger than a flashlight, but it's lasts FOREVER.....well almost :o. It's a little lantern that I was given on christmas and damn, the thing hasn't needed new batteries yet. Here are the stats from the energizer site:
500 hour LED area light
Area light, LED nightlight and detachable LED pocket light
Packed with 3 Energizer® MAX® D batteries
It has a regular krypton light, led light, and a low power orange light for a nightlight sort of thing. It also has a small keychain led light that pops off the top of the lantern. It will last the 500 hours as long as you use either one of the LED functions. The LEDs on this are actually brighter than the krypton light that it comes with. Great to have around camp for an extended stay. Hope this helps, J.
I really depends on your uses, needs and requirements. I think you've decided that a two-3V battery light is you max size requirement, which will give you longer run-times than single battery lights. For EDC, I really like single battery LED's, they're more compact and the run times aren't necessarily half of a two-battery version.
Again, I don't know your exact needs, but if you just want a very bright light, than you'll have reduced run times. A lot of the newer LED's are regulated with optional brightness output levels. These give you the option of have a very bright light, or adjusted to a lower, longer lasting output level.
Do you always need a full-output level? I don't think so. The majority of tasks should be using the minimum amount of light needed. Reading in a tent or looking over a map, rumaging through your pack at night, navigating a large sleep tent with others sleeping, getting the camp stove prepared before sunrise, adjusting a piece of equipment at night, etc. etc. One of the best lumen output levels I've found is anything between 10 and 30 lumen...that's what I would consider optimum utility lighting and it also gives you much longer run times.
Novatac, previously known as HDS, makes a bomb-proof light. I can only relate my experiences in Iraq for over a year, and it's held up well...I had a few to T&E and passed them out to a few users in different units (AF security forces, Engineer route-clearing teams, Commo-teams, and ODA team, Blackhawk piolots and crew chiefs) to use and evaluate. Bottom line, it's built like a Surefire but has the excellent options found on Fenix LED's. It's my current EDC. Now, I mentioned Fenix lights, and for the price, features and durablity, you won't find to many lights in that range with as many features. I have almost all of the original Cree versions and they are absolutely great. I heard that thier construction and design wasn't very robust, but I can tell you if they can make through a combat zone for 12+ months under conditions most people stateside will never see, than they get my full endorsement.
Some also mentioned headlamps. This is another great tool for the tool box. Most likely it won't be your EDC, but you can improvise. I used a Nite-Ize headband that holds regular hand-held flashlights for a simple headlamp. The diameter of the Fenix lights was perfect, the Novatac and thicker Surefire's were a little large (the Novatac did fit though) and most two-battery lights were a little too heavy. Anyways, it gives you a great "no-hands" option of lighting for tasks requiring both hands.
I used both the Petzl Tikka (TAC Tikka Plus) and Princeton-Tec EOS 3xAAA headlamps and loved both. The EOS gives a better throw, but for short range utility (up to 12-15 feet outdoors), they are definately worth it. They do burn batteries a little more, but even at the lower output levels, you get around 5-6 days of lighting...actually that's 24 hours-a-day, so for just night-time use, you can double or even triple that depending on your needs and activities.
Another great little headlamp is the Zebra light http://www.zebralight.com/index.php?main_page=product_info&products_id=183&zenid=9dobtuu9c36s2u5s4p93prepk5. For those that like to use a single battery type (and what I usually take backpacking), I like the Fenix L1D, single AA battery light along with this little Zebra light as a headlamp. I'm quite impressed with the Zebra...it has great output!
Hope this helps,
ROCK6
sp
Maybe I can help you. I'm new to BF, but well known on CPF- i evaluate LED lights for manufacturers. Here are a couple of guidelines that may help, and a couple of suggestions:
1. avoid "coin cell" lights, as they simply don't throw enough light and the coin cells can be tricky to change out in a dark/wet/cold environment.
2. for hiking/camping, you don't need an expensive "cult" llight, nor one that has lots of output- theruntime simply won't be there.
3. don't get a light that's VERY small or of a form factor that won't be easy to spot in the bottom of a pack.
4. here is the "must" list, IMHO:
water resistant
floody in the beam shape
long runtime
extremely well made- you don't need failures miles from nowhere
lithium-cell powered: temp stable from very low to very high
as mentioned above, maybr consider a headlamp
>a suggestion might be the Inova X5-- 20+ hours runtime, bright enough, waterproof, and 1/4 the cost of a Novatac or Surefire
fell free to post or PM me if I can help.
Inova are the best bang for you buck lights going. I have the X5 and the X03 and they are both superb. The X5 runs forever and it is damn near indestructible, the X03 throws out a fantastic amount of light and is equally tough. Best of all is the price! I have Peak LED Solutions, Surefire, HDS and Fenix for comparison. Inova X5 is third from left in pic and X03 is far right.
However, if you want truly waterproof, not water resistant, HDS/Novatac is the way to go.
But 4-6hr battery life is max for it. ...
sp
I don't know if you have the current Cree version as I do. It is a great light.
In March, you will be able to buy a 2-level replacement KX2 head for your E2L flashlight from Surefire. The new version KX2 will provide selectable 60 and 3 lumen output.
Surefire specifies a battery life of 100 hours when using the 3 lumen level.
Nice thread. Love the light pics!
